Introduction: K'nex - Browning M1919 Instructions
Hey guys and today I bring you instructions for the M1919 Browning that was used in World War I (M1917), World War II, Korean War ,Vietnam War and the Bay Of Pigs Invasion. One of its counterpart known as the M2 Machine Gun (nicknamed the "Ma Deuce") is still being used by most NATO forces since World War II because of its low recoil and that the barrel for it is 45 inches long, the range for the M2 is 4.5 miles.
But before we go any further, I would like to thank and give a lot of credit to Instructables member Smithinator as I did follow the pictures that he posted of his own M1919 Browning to make this one. When I finished it, I made quite a few changes to it to and of course I have made instructions for it so you can have your very own M1919 Browning. The M1919 Browning took me 4 hours and 30 to build it and this does include making minor tweaks and adjustments.
Good Points
· Very Realistic
· Detachable Bipod
· Includes Ammo Belt
· Comfortable Handgrip
· Good Iron Sights
. Ammo Belt Is Removable
Bad Points
· Uses A Few Cut Pieces (See Parts List)
· Doesn't Shoot Because It's Just A Model
Specifications For A Real M1919 Browning
· Designed - 1919
· Number Built - About 5,000,000
· Ammo - Mainly .30-06 Springfield or 7.62x51mm NATO
· Rate Of Fire - 400 to 600 Rounds Per Minute
· Powered - Short Recoil Operation
· Magazine - Usually 250 Round Belt
· Range - Between 587 and 1500 yards
In Call Of Duty: Zombies, the Browning M1919 is available in all World At Wars maps only and not in Black Ops versions where it is only available from the Mystery Box for 950 points. It is among one of the most fan favourited weapons because of it's high damage, large ammo count and low recoil but it's reload time takes 6 to 7 seconds so Speed Cola is very strongly recommended and it is up to the player to buy Double Tap to increase the rate of fire as since it is slow but it will use more ammo. When it is Pack-A-Punched for 5000 points it becomes the "B115 Accelerator" where you get more ammo and a quicker rate of fire. It is one of the best guns in Call Of Duty: World At War in the higher rounds against the zombies and it does do a excellent job at giving you tonnes of points.
Also check out my other creations and instructions
https://www.instructables.com/id/Knex-1975-CZ-75-Instructions/
https://www.instructables.com/id/Knex-Biplane-Instructions/
https://www.instructables.com/id/Knex-1976-MP5K-Instructions/
https://www.instructables.com/id/My-Knex-Weapons-Of-2013-2014/
https://www.instructables.com/id/Knex-James-Bond-Helicopter-With-Saws/
https://www.instructables.com/id/Knex-1979-SPAS-12-Instructions/
https://www.instructables.com/id/Knex-Galvaknuckles-Instructions/
Step 1: Parts List
If you have any trouble or need more pictures just leave a comment and I will get back you ASAP. I strongly advised you to collect all the pieces before you start building. Also I have added a few notes throughout this instructable to make it more easier to understand something if you run into any difficulty.
Green Rods - 363
White Rods - 221
Blue Rods - 29
Yellow Rods - 8
Red Rods - 4
Green Connectors - 4
White Connectors - 60
Blue Connectors - 2
Yellow Connectors - 193
Red Connectors - 24
Light Grey Connectors - 8
Dark Grey Connectors - 58
Orange Connectors - 3
Y Shape Black Connectors - 30
White Connectors - (cut, see step 6) - 6
Red Connectors - (cut, see step 3) - 3
Yellow Connector - (cut, see step 3) - 1
Yellow Connector - cut, see step 4) - 1
3.1cm cut Rods - 1
3.9cm cut Rods - 2 (These can be replaced with a blue rod)
3.9cm cut Rods - 3
Hinge Black Half - 6
Hinge Blue Half - 6
Blue Spacers - 8
Total - 1044
My Ammo Belt
Blue Rods - 100
Yellow Rods - 1
Dark Grey Connectors - 251
Orange Connectors - 1
Tan Connectors (with the little tab cut off) - 8
Y Shaped Black Connectors - 3
Blue Spacers - 200
Total - 564
Step 2: Handle
Step 3: Magazine Well Part I
Step 4: Magazine Well Part II
Step 5: Barrel
Step 6: Update
Step 7: Bipod
Step 8: Ammo Belt
Step 9: Done
Well done you made it to the end, I do hope you have enjoyed building it.
Zombie Quotes About The Browning M1919
"Now I've got something fun to bring to the party"
"In my hands this weapon will destroy them"
"This will hurt like syphilis, believe me I know"
Thanks for building it, please leave a comment in the box below and subscribe
