Introduction: Knex Ball Machine: Elysium, Elements
Hello!
Here are the instructions for the new elements from my knex ball machine Elysium.
If you have any questions or problems, you can always comment or send me a message.
There are a lot of image notes in this instructable, if you're building an element please read them because sometimes they can be helpful.
Thanks for watching / building!
~Sandroknexmaster~
Step 1: Ferris Wheel
Just another ferris wheel, very simple.
Step 2: Swinging Bridge
A cool looking element where one ball waits to leave the bridge once a second ball enters. Gravity resets the mechanism.
Step 3: Down-up Arm
First going down, then going up again. This is a rather big element, but it looks good in a ball machine and works very well.
Step 4: Dizzy Gears Drop
It works perfectly and is funny to watch. You can make it as high as you want.
Step 5: Pendulum
This is a big element that took surprisingly little time to create. Making the movement of a pendulum, hence the name, this element works perfectly.
Step 6: Mini Panel Zigzag Drop
You can make this element as high as you want.
Step 7: Yellow Zigzag
This element uses a lot of yellow rods and green connectors, so if you have a lot of those parts left, this element is perfect for you. The last pictures show you how to attach the element to a red rod frame, but you can always improvise and do it your own way if you want.
Step 8: Chainsaw Drop
You can make this element higher if you want. This one is the same as in Elysium.
Step 9: Back and Forth
This element was invented accidentally while trying to make something else. I'm not sad about it, because this one looks good and works well. You can easily choose the side for the entrance track, just attach it to the side you want.
Step 10: Vertical Track Drop
This is not really an element, but it was used in Elysium and I think it can be useful for you too. These things place the ball perfectly on the track, very useful for when you want to make a steep drop. The one with yellow rods was used in Elysium, but I also made a blue rod version, so you can easily attach it to a red rod structure. The track sticking out at the top is not necessary, I just didn't want to cut it.
Step 11: Green Ring
This is made to decorate. You can use it for whatever you want: Make a ball jump through it, attach it on top of your machine, make it longer, make multiple rings to combinate,... It's not really an element, but I thought it was worth to share it with you.
1 Person Made This Project!
- LindaP5 made it!
55 Comments
1 year ago
Hey Sandro I was wondering. There are 120 images on here of the pendulum element and it seems like it would take a lot longer to build due to it's size. So how did it take little time to build?
Reply 1 year ago
./,/.,/.,/./.,/.,/.,/.,/.,/,/.,/.,/.,/.,/.,/.,/.,/.,/.,/.,/.,every thing
1 year ago
starting starting im making it look like bowsers castle in super Mario 3d world
Reply 1 year ago
best game ever
1 year ago
include incude im making a ball machine
Reply 1 year ago
I am
6 years ago
Kind of like my element on eclipse :D
Reply 6 years ago
Which element?
6 years ago
Wow, more beautiful elements. I like the way you build them, they always work perfectly.
Reply 6 years ago
Thanks! 3100th comment btw :p
6 years ago
hi I want to get started with KnEx ball machines but I don't have a ton of pieces. and I only have micro KnEx chains and gears. could you build a small compact ball machine that would use a golf ball so I can get started?
Reply 6 years ago on Introduction
I would like to do that, but the problem is I don't have a lot of time at the moment. Maybe when I find the time for it.
As always, a really good job on this elements Sandro!
Thanks!
WOW. How long did it take to take all those pictures! Golly! XD
A few days :p
Wow. XD
Man you're a genius when it comes to Knex! ;)
Thanks :p
Cool! I wish I had a working KNEX motor so I could make a ball machine.
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR3.TRC1.A0.H0.Xknex+motors.TRS0&_nkw=knex+motors&_sacat=0
