Introduction: K'nex - Mystery Box
Hey guys, now instead of doing my usual routine where I use pictures of K'nex guns from other Instructables members to build my own versions of theirs and then write a review on it but I have done something completely different.
Because I do enjoy playing Call Of Duty: Zombies alot, I got the idea to build this when youtuber ZaziNombies made his own Mystery Box out of over 10,000 lego pieces and it thought to myself that I could make one out of K'nex and I knew the dimensions for one.
Anyway let's talk about the Mystery Box, basically it appears in every single zombies map and what it does is, it gives you a random weapon for 950 points. After the Mystery Box has been used several times a teddy bear appears and it moves the box to a different location in the map and you get your money refunded as well. If you pick up a Fire Sale power up, the box will spawn at every possible location and the price is reduce just to 10 points but this will only last for 30 seconds.
Parts List
Green Rods - 3187
White Rods - 2166
16mm Black Rods - 34
32mm Black Rods - 32
White Connectors - 780
Black 8-Way Connectors - 28
Blue Connectors - 962
Yellow Connectors - 129
Red Connectors - 6
Purple Connectors - 1110
Hinge Black Half - 33
Hinge Blue Half - 33
Total - 8500
Good Points
· Looks Like The Real Thing
· Doesn't Use Any Cut Pieces
· Does Included The Question Marks That Appear On The Lid
· Does Open And Close
· When It Open's It Creaks Like The Real Thing
Dimensions
· Height - 27cm
· Length - 120.8cm
· Width - 27.3cm
Overall I 'am very pleased with my Mystery Box, and is the only one on Instructables that is made out of K'nex when it is compared to the ones that are usually made out of wood.
Also check out my other creations and instructions
https://www.instructables.com/id/Knex-1975-CZ-75-Instructions/
https://www.instructables.com/id/Knex-Biplane-Instructions/
https://www.instructables.com/id/Knex-1976-MP5K-Instructions/
https://www.instructables.com/id/My-Knex-Weapon-Of-2013-2014/
https://www.instructables.com/id/Knex-James-Bond-Helicopter-With-Saws/
https://www.instructables.com/id/Knex-1979-SPAS-12-Instructions/
https://www.instructables.com/id/Knex-Galvaknuckles-Instructions/
Thanks for reading, please leave a comment in the box below and subscribe/
