Introduction: Knex Rapid Fire Grabber Gun
I was wondering what to do for a new knex gun so i turned to the make books, and there I found a Knex Claw Grabber so i began to build it but instead of making the claw i added a barrel, my new loading system and a magazine and to my surprise i could shoot very quickly, so i modified it slightly and i made this. you can fire it fast from the hip or aim from the shoulder, you fire it by pulling the handle right back and then releasing it with your fingers spread as below.
i know it isnt finished but i wanted to just get it published.
Step 1: Handle
Follow the instructions on the pictures.
Step 2: Handle Continued
After you have made the main part of the handle in the first step you will want to strengthen it as it will bend as it is.
1. Take 2 green connectors and attach them to a red rod.
2. Clip 4 orange connectors to a red rod as in the picture, then add 2 yellow rods to 2 of the the connectors and then to white rods with a grey spacers on to the other 2.
3&4. Clip a tan connector and 2 blue spacers on to a blue rod and attach it to the rest of the handle.
5. Connect the strengthener to the handle.
Step 3: Main Body
1,2,3. clip a purple connector to a blue one and then clip a blue rod on to the blue connector and clip that to 2 purples as in the picture. then put 2 green connectors on to each side of the purples with a green rod. then clip 2 red connectors to the blue connector with green rods and add green and white rods to each red connector.(make 2)
Step 4: Connecting
Read the pictures.
Step 5: Magazine, Loading System and Barrel
make
Step 6: Firing Pin
make
Step 7: Extras-Handle
how the make the handle to fit the red rods.
once you have made the handle, clip 3 yellow connectors to a white rod and put that on to the red rods as in the pictures below. once it is on you can slide some spacers on too to keep it in place.
92 Comments
12 years ago on Introduction
this is truly awesome, 5*.
13 years ago on Step 6
U joined on my birthday!
Reply 12 years ago on Introduction
you're kicked from the party*
13 years ago on Introduction
how do you fire? maybe you culd ad id
Reply 13 years ago on Introduction
You pull back and then release the handle.
Basically this is semi auto
technically
No, it has no trigger as such, just a handle which you release.
yeah but every time you pull it back and let go it fires here examplehttps://www.instructables.com/id/Semi-auto-Knex-Rifle/
That one is semi-auto, you pull back the 'trigger' and it releases the pin but on this gun you have to release the pin.
Ok its slightly off but it falls under the same category,
14 years ago on Introduction
im gonna make a knex turret! i will hav a base with motor in and then a remote control so i can move the main gun on top. i will probs use a gatling on top or design a new mg! im new so if i make it, it will b my first instructable yeah!!!! acker123
seems inmpossible, but go for it anyways
Reply 14 years ago on Introduction
wat u should do is mount a knexacutioner on top
as your main gun
the 1.02
pretty cool. looks sorta like a p-90
rofl wtf? no way its a f-n
nice idea.
