Introduction: Mickey & Minnie Topiary
I made my son (6yr) and daughter (2yr) a "Mickey & Minnie Topiary" for their Halloween costume this year.
Everyone loved them and they were a big hit everywhere we went!
It took about 2 weeks to make the costumes.
Paper Mache Head:
Newspaper
Paper Plates
Elmers Glue White
Big Bounce Ball
Helmet
Long Bolts, Nuts & Washers
Green Paint
Hot Glue Gun & Hot Glue Sticks
Plastic Grate Sheet
Under Body:
Green Long Sleeve Shirts
Green Leggings
Green Shorts
Green Shirt
Yellow Bowtie
Minnie Bow
Cartoon Gloves
Upper Body:
Spanish Moss
Ivy Leaves Vines
Shoes:
Old Shoes
Stuffing
Green Duck Tape
*For my two kids it took about 6 - 8oz bags of Spanish Moss and 2 -24pk of ivy vines. Also took about 3 - 100pk of hot glue sticks.
Step 1: Paper Mache Heads
We took a bounce ball and blew it up to the size head we needed to fit each child.
Then we used the ball as a base to paper mache the head using a half and half mixture of water and Elmers White Glue, with newspaper to make the form. Make sure to cover the ball with plastic wrap before putting on the strips of newspaper. We use paper plates to make the ears and paper mache'd them also.
Once the paper mache was dry, we cut a rectangular viewing area out of the head so that they can see. We used a plastic grated sheet and painted it green and glued it into the cut out spot.
Since our kids are pretty young to just wear the heads, we used the inside part of their bike helmets and attached them to the inside of the heads. We used nuts, washers and a long bolt through the top of the head to the helmet on the inside. Then we used bolts through the sides of the heads to center the helmet, which with this we just hot glues them to the sides of the helmet inside.
Once finished with supporting the helmet inside, it is time to paint the whole head with Green Paint.
Once the paint is dry, you can start gluing the Spanish Moss onto the entire head. For the nose, we just bunched up some Spanish Moss to form the nose.
After the Spanish Moss is placed, you can start hot gluing the Ivy Leaves onto the entire head...which takes awhile, LOL.
For the finishing touch, we added the Minnie Bow to the Minnie Head.
FINALLY THE HEADS ARE FINISHED!
Step 2: The Body
For the body, we bought green shirts, leggings, shorts and skirts to use.
We hot glued the Spanish Moss on all the clothes.
Then we hot glued the Ivy Leaves on all of the clothes.
We only glued on to the spots that were visible after we tucked the clothes in and put the short and skirt over the leggings.
For any areas that will rub together, like in between the crotch area and under the armpits, we only put Spanish Moss, NOT ivy leaves. This helped it not get messed up from rubbing.
For the finishing touches, we hot glued a Yellow Bow to Mickey's outfit and we also purchased cartoon hands to use.
Step 3: The Shoes
We took old shoes and duck taped the shoes while adding stuffing to make the shoes look oversized. You will need to test fit the shoes as you go along to make sure that they can slide the shoes on and off.
We hot glued the Spanish Moss onto the shoes.
Then we hot glued the Ivy Leaves onto the shoes.
We found out that in between the shoes is another area that gets rubbed from them walking, so we only kept spanish moss in between the shoes.
Runner Up in the
Halloween Contest 2019
14 Comments
1 year ago
i thought it was real
Reply 1 year ago
Thanks!
2 years ago
These are such cute and unique costumes!
Reply 2 years ago
Thanks so much!
2 years ago
How did they get the costumes on and off? Were they able to slip over their heads, or did you have an opening down the back? What is the purpose in using the Spanish moss? In the photos at least, all I see is the leaves.
Reply 2 years ago
They were able to slip them on and off. The shirts were tight at first because of everything being glued on it and the arms not bending too much but after each time it got stretched out and easier. The pants were easy to get on and off.
You can see the spanish moss sticking out from underneath it. If I did it again, I would spread out the leaves more so that you could see the spanish moss more. It looked really cool being able to see it sticking out from underneath. It gave a real feel to it.
2 years ago
awsome costumes
Reply 2 years ago
Thanks!
2 years ago
That is such a cool idea! Love it. Thanks for sharing.
Reply 2 years ago
Thanks so much! Glad to share!
2 years ago
awesome costumes!
Reply 2 years ago
Thanks!
2 years ago
Wow nice super finish
Reply 2 years ago
Thanks!
