Introduction: How to Make a Friendship Bracelet
Prepare the Materials:
6 mm natural black agate round beads X4
Two No.72a bright red cords, one is 1.5 meters long and the other is 0.8 meters long.
Others:Scissor, Measuring tapes ,lighter
Step 1:
Put the two cords together to tie an overhand knot from the middle of two cords.Click here to see the overhand knot tutorial.
Step 2:
Tighten and fold the cords in half and tie the four red cords together with an overhand knot. You will make a loop easily. Click here to see the overhand knot tutorial.
Step 3:
Tighten the knot. Put 2 short cords between 2 long cords as the holding cord.
Step 4:
Start braiding bracelet by using the flat knot.Click here to see the flat knot tutorial.
Step 5:
Thread a 6mm agate bead in the middle of cord after you braided it about 6 cm long.
Step 6:
Continue braiding bracelet by using the flat knot. Click here to see the flat knot tutorial.
Step 7:
Thread a 6mm black agate bead again on the middle of cord after you braided it about 1 cm long.
Step 8:
Repeat the same step 6.
Step 9:
Repeat the same step 7.
Step 10:
Repeat the same step 6. Continue braiding bracelet by using the flat knot. Click here to see the flat knot tutorial.
Step 11:
Thread the last 6mm black agate bead in the middle of cord after you have braided your bracelet about 14.5 cm long.
Step 12:
Trim the excess working cords. Then burn the ends.
Step 13:
Tie an overhand knot at the end of cord. Trim the excess cords and burn the ends. Click here to see how to tie an overhand knot instruction.
Step 14:
Done it!
