Introduction: Professional Water Rocket Guide
This Instructable will show you the how to build and fly water rockets. Featuring two stage rockets and drop away boosters, and also some basics.
This instructable is based on my knowledge of water rockets, that I have learn in the past few years.
I am not responsible for any damage you infict on your self or others from launching or building water rockets
Have fun building and flying!
Step 1: Lets Get Started
A water rocket is propelled by pressurised air forcing water down though a nozzle. This creates thrust.
If you took a standard two litre fizzy soft drink bottle and pressurised it to120 psi the rocket would reach about 100 or so feet.
But then if you took 2, two litres bottles and pressurised it to 120 psi again the rocket would go about 150 feet or so because the rocket has more air in it therefore creating more thrust. The rocket will only go 50 feet more because of the added mass. You can stop this by making a two stage rocket. A two stage rocket will work better because it would not have to carry the full payload on all of its flight.
Step 2: How to Build a Fins and Nose Cones
In the next few steps you will be shown how to build the basic needs of a bottle rocket.
This step is to get to grips on what a rocket needs.
Step 1: nose cone
cut the top and bottom off a 1.25 litre bottle. Then cut the neck off the top.
Step 3: Step 2: Nose Cone
Step 2:
Cut a ping pong ball in half with a craft knife,
Then glue half of the ping pong ball into the top of the 1.25 litre bottle 'top'.
Use a Plastic adhesive glue, Or if apperance doesn't matter you could just tape it on!
Step 4: Step 3: Nosecone
Glue or tape the nose cone to the top of the rocket.
Adding wieght to the nose cone may help, It will move the centre of gravity higher, thus being more stable.
Step 5: Fins
This stage is still the basics of how to make a water rocket but may help in later projects.
Step 1:
Print off the fin template from the link below... Or design your own..
Then glue the fin template on to cardboard, then cut it out or use it as a template for corregated plastic.
Step 6: Attach the Fins
You can attach the fins by
1. Glueing them on
2. Taping them on
To glue correx fins to the rocket use PL premuim or a plastic glue.
To glue Cardboard fins on use PL premuim or gorrilla glue.
Step 7: Now for the Professional Water Rockets
Professional water rockets can vary from big one stage rockets to 2 stage rockets with drop away boosters.
This stage of the instructable will show you how to make a big one stager and how to couple or splice bottles together.
step 1 : coupling and splicing
How to couple bottles
first drill a hole about 7-8mm in width in the bottom of one of your bottles.
Next screw the male end of a plumbing coupling which is about 8mm in width into the bottom of the bottle, then seal it with a sealent glue. Next drill an 8mm hole in the other bottle cap and then insert the male end in to it. Whist the bottle cap is off the bottle, screw the female end into the other side of the bottle cap (side facing the inside) If you want you can seal it with glue as well.
Step 8: Splicing
How to splice
To join two bottles together like in the picture to create an air tight seal you need three bottles
first cut the bottom ends off two of the same sized bottlles
Then cut both ends of the same sized third bottle and place that in the two exposed ends of the bottle
Next glue the third bottle in the 2 exposed ends.
Step 9: Launchers
The laucher that my water rockets are made for was designed by Nasa.
The launcher lets you vary the nozzle size so you can get better performance from your rocket.
The next few steps will show you how to make it.
Update:
PDF from NASA below
Step 10: Launcher Parts
Below are the materials you will need for the launcher
qty part
1 1/2 inch wood (any type)
2 10mm bolts
1 10mm metal drillbit
1 10mm wood drillbit
6 10mm nuts and washers
1 presta bike valve (you can get this from an old inner tube)
1 rubber bung
1 bike pump
2 tent pegs
4 L (shaped) brackets
2 nails
Step 11: How to Make the Launcher and Nozzles.
below is the link for the pdf for making the launcher.
The launcher can hold any type of pressure depending on the rubber bung.
If you have a different nozzle size then you can adjust the nuts on the bolts so the pins can line up with the hole in the 90 degree mending plate and the neck of the bottle.
Step 12: Two Stage Rockets
The mechanisim I use to stage my rocket is different to Air Commands or any other two stage water rocket.
I have tried to make the stager compact. The stager can link to a servo or a pressure switch.
The instructions for it are on the next few steps.
Step 13: Stager
Materials
QTY Material
1 22mm pipe any lenth over 15cm
1 plywood or you can use plastic. (to hold the bottle in place)
1 inline non return valve..... One from a ballon pump will do
1 a 1st stage of a bottle rocket and a 2nd
instructions
1. insert 2cm of the 22mm pipe in to the 1st stage. ( pic1)
2. use epoxy or pvc sement to seal it. (pic 1)
3. insert a non return valve into the pipe and glue it.
3.work out the dimensions of how long and wide the plywood or plastic needs to be, to hold the bottle in place. Then cut it out using image 2 to help you. The hinge is mounted on the pipe clamp.
4.when you slide the bottle on (use vaseline to seal it) make sure the pipe clamp is right next to the neck on the first stage. This will have your hinge on, next clip your hinge onto the bottle neck so it is tight and won't fall off.
Step 14: Drop Away Boosters!
These boosters are so easy to make because they are only held on by the upthrust of the bottles.
These drop away boosters are differernt to Air Commands.
For the drop away boosters you will have to make three of the launchers.
Instructions(drop away boosters)
1.measure your drop away booster bottles against your main rocket. Make a mark (dot or line) where the top of the booster meets on your rocket.
2.use pic 1 to help you, where you marked a dot on the booster glue the advanced fins together and stick the bottom of the fins on the marked dot with duck tape or glue. The Advanced fin template is on step 15.
3. test the rocket!
Step 15: Advanced Fins
These advanced fins are for bigger rockets and are very good for two stage rockets and rockets with drop away boosters.
for fins print off the template below
Step 16: Payloads and Parachutes
The next few steps will show you how to make a parachute system followed on by a payload bay
Parachutes:
The parachute system used by me 'OscarThompson' is a simple gravitational deployment.
The nose cone is fitted on the rocket loosely and when the rocket reaches its maximum altitude the rocket will fall back to earth nose first and as the nose has a weight in it, it falls off deploying the parachute inside.
Step 17: Step 1,2,3,4 of Parachutes
Step one:
Find a payload bay for your rocket. any size to fit a parachute
step two:
Build a nose code like as shown in steps 2 and 3. Your nose cone either needs to fit loosely on top of the payload bay or loosely in it.
step Three:
cut a hole in the payload bay and the nose cone so a string can fit though it and be knotted.
step four:
tie the parachute string to the string you have tied to the nose cone and the payload bay.
Step 18: Payloads Steps 1,2,3
Payloads
payloads are used to carry equipment such as altitude meters, accellerometers or even a slug (wierd, but the g-forces can kill it!)
Step one:
cut the bottom off any size bottle.
step two
cut two disks the same width as the bottle out of corregated plastic
step three
cut a strip out of plastic the same width as the bottle but a little bit smaller in length than the bottle
Step four:
Glue them together and when dry put your payload into the payload section of the rocket.
Step 19: Rocket Designs
You are free to look at these pictures if you need help for a design.
Step 20: Thank You for Reading
If you have any problems please leave a comment
104 Discussions
3 years ago
this is too hard can u make one with less steps that still flies
4 years ago
how to make launcher
Reply 3 years ago
ones like this: https://www.instructables.com/id/water-rocket-launcher/ work really well
4 years ago
same
5 years ago
hey i've never made one in my life any advice?
Reply 4 years ago
only advice, pressure is a beast in a locked up cage, handle it with care... :)
6 years ago on Introduction
i cant understand how the parachute will open ???
Reply 5 years ago
there is no parachute. you just let it crash, make any repairs and go again
5 years ago
WOW, I have built bottle rockets before, but, this is AWESOME!!!!!!!!!!!!!!!
10 out of 10
oh i made it some years ago later
I think they are referring to the fact that he may have placed an illegitimate copyright tag on his work. Doing so without first acquiring a legal copyright is illegal in the US, I believe. Yes, he may own some or all of the ideas/photos, but he is not automatically awarded a copyright or patent. I'm no expert but I think US law provides that he must first go through the process with an official agency (US Patent Office) to determine if this work is not only his own, but that it is copyright-worthy (or patent-worthy). The comments above are questioning the fact that he acquired an official copyright with such an insignificant amount of work.
Reply 6 years ago on Introduction
I just looked into this further, and I was wrong on the point of automatic awarding of a copyright. According to Copyright.gov "Your work is under copyright protection the moment
it is created and fixed in a tangible form that it is perceptible
either directly or with the aid of a machine or device." However, I after reading more of this article, I believe people are confusing Copyrights with Patents. It depends on what he is trying to protect, as Copyright does not cover ideas, facts, systems, or methods of operation. If he wants these protected he will need to look into getting a patent or some other type of protection. The big deal here is that he's claiming a copyright on material that he is intending to be public. Which is just making him look like a jerk.
that looks intense
Dude is this okay.
What are you doing?
but cool
8 years ago on Introduction
cool rocket
11 years ago on Step 13
do you actually own the copyright to these diagrams, i highly doubt you have gone through what is needed to have the copyright for them and putting that little "copyright OscarThompson" in your pictures doesn't actually do anything
don't be mean to the person it is a good rocket
Reply 9 years ago on Step 13
He is just putting acknowledgment that it is his.
