Introduction: Shoebox Suitcase
I decided to give our girls creative suitcases for Christmas. And I wouldn’t be the Creative Mom if I didn’t think instantly about not buying them but making them. Fortunatelly, I had two great shoeboxes at home. I wanted to make the shoebox suitcases because I realized that shared property isn’t a good thing even for kids sometimes:-) There can be a hundred crayons in the box but they both want the same one at the same time. So my (naive) idea is that each girl will have her own box where she will keep her creative things.
If you’re a parent of a girl at the age around 6 you are probably (forced to be) familiar with the series called Miraculous Ladybug. Or girls love it. So since I found these two shoeboxes with Ladybug I had half of the work done because I could just keep the design.
I won’t always give you the exacts measurements because you can make the suitcase from any shoebox and easily adjust the measurements of the other material.
shoebox
thick synthetic band/stripe
sheet of felt
velcro (I used 2 circles)
cutter
glue gun
scissors
if your shoebox doesn’t have the desired design, you’ll also need material to re-design it like paint, paper, stickers and similar
Step 1: Prep and Cut
1. shoeboxthick synthetic band/stripesheet of feltvelcro (I used 2 circles)cutetrglue gunscissorsif your shoebox doesn’t have the desired design, you’ll also need material to re-design it like paint, paper, stickers and similar.
2. First, I cut off one of the long edges of the lid.
3. Then I cut out the following felt pieces:
- 6 circles
- 2 rectangles 9 cm tall and of the same width as the long inside of the box
- 1 thin stripe as long as the long inside of the box
- 2 thin stripes that are as long as the shortest inside of the lid (it was some 3 cm)
4. I glued the this stripes on the edges of the lid where I previously cut off the long side.
5. I then glued the felt circles at the corners of the box (all 4) and 2 corners of the lid (this would be the front of the box).
Step 2: Attach the Lid
1. I glued one half of the rectangle inside the lid on the side of the cut off edge.
2. Then I glued the other half inside the box to join the box and the lid.
3. I glued the other rectangle on the outside where the lid joins the box.
Step 3: Stripes and Handle
1. I measured the length of the belt so that it goes all around the box and overlaps in the front. And, of course, there need to be two belts. I melted the ends to frevent fringing.
I glued both belts to the box except for the front side where they overlap. Then I also cut a shorter piece of the belt and glued it in place as a handle.
2. I cut the velcro circles in half and glued them onto the belts. The oposite pieces of the velcro have to allign.
Step 4: Final Touch
1. At the end, I glued a felt letter on each suitcase so the girls recognize which one belongs to whom.
2. And I filled the suitcases with some creative supplies:
finger sponges, color ink pads for stamping, paper punches, alphabet stamps, color, Washi tapes, many different stickers, wax crayons...
The girls were excited and started using the content of their suitcases almost immediatelly (mostly to decorate the suitcases). They felt a little sorry for their baby brother and gave him some ink pads to chew on (at this point I had to step in). So overall I think this present was a success!
