Introduction: Snow Flake Bead Earring
Hey there!! I'm gonna show you how to make this pretty snowflake earring.
Step 1: You Will Need...
1. Blue beads - big and small ones
2. Oval white beads
3. Tiny white beads
4. Nylon wire - 1/2 metre for each earring
5. Earring hooks and rings
6. Scissors
7. Glue
Step 2: Let's Get Started!!
Get 1/2 a metre of nylon wire and string the beads as show. The small blue bead goes in the middle.
Step 3:
In the same bead order, add one layer on each side of the first layer.
Step 4:
Similarly, add the third layer on either sides. Finally, add the last layer in the gap.
You might have to adjust the beads to space them equally.
Get the nylon wires through a single bead and stick them with glue so that the beads don't fall off.
Step 5:
The ring that goes with the hook, is opened wide and put through the big blue bead. Before you close the ring, put the hook through the ring. Close the ring properly to prevent the beads from falling off.
That's it! You got yourself a beautiful snowflake earring.
