Introduction: Snowflake Necklace Pendant
This is what your pendant will look like after you have designed, printed, and decorated it.
Step 1: The Die
I used tinkercad for the designing of my pendant. I got my die and changed the size to a length of 22.58 millimeters, a width of 22.58 millimeters, and a height of 22.58 millimeters.
Step 2: The Snowflake
I got a snowflake and changed its size and angle to a length of 19.76 millimeters, a height of 19.76 millimeters, and a depth of 2.82 millimeters. Be sure to change it to a hole instead of a solid object.
Step 3: Placing Your Snowflake
Make sure that the snowflake is centered in the side of the die. Repeat this until all faces of the die, except the bottom, have a snowflake on them.
Step 4: The String Loop
The loop for the string is a torus shape. It is 5 millimeters by 5 millimeters with a height of 4 millimeters. The radius and the thickness do not need to be changed. It should be placed at a -45 degree angle. and rotated 45 degrees.
Step 5: Before Printing
This what your object should look like before being printed.
Step 6: Printing
I printed it on a 4 inch by 4 inch by 4 inch print bed. It printed as a 1 inch cube. Be sure to ceck on your progress while printing to ensure that it has not malfunctioned. After printing be sure to sand the object and paint or decorate as wanted.
Step 7: The Final Product
This is my pendent after being printd, sanded, and painted.
Jewelry Challenge
3 years ago
Lovely little pendant :)
