Introduction: Super Special Laptop Sleeve (**With Updates**)
After reading this I thought it sounded like something that might be fun to try making.
Since my mom's birthday is coming up (Hi Mom!), I figured it might be neat to make her a nifty laptop sleeve emblazoned with the covers of her favorite newspapers (The New York Times and The Washington Post). Just to make it extra special, I used a photo-editing program to change the news a little, but you could also leave it as is - especially if something interesting was covered.
I also made one for myself with a nifty computer repair flowchart on one side, and the circuit map of an Apple-1 on the other. There are probably a billion different things that you could use as an image (repair guides might be cool/helpful), whatever floats your boat!
Because it requires a hot iron and needles, make sure to be careful. This would be a great simple project to teach kids some sewing techniques (rounded corners and rolled hems), and the results are pretty nice!
*note: make sure to check out the tips in Step 5*
Step 1: You'll Need. . .
- some t-shirt transfer paper (at least two sheets), 8.5"x11" (make sure it's compatible with your printer)
- an iron
- a printer
- a scanner (if you don't have your images in digital format)
- a newspaper or two, depending on if you want the two sides to be the same or not (if you don't want to go through the hassle of scanning a newspaper, etc. you can also look for images of newspapers online)
- a computer with photo-editing software (Photoshop, G.I.M.P., etc.)
- other images and things (if you want to change the news)
- some fabric (I used some canvas) - you'll need enough to cover the laptop like a book jacket, and as well as extra around the edges for seam allowances)
- needle, thread (or sewing machine if you have one - it makes this much easier)
- pins
- a pillowcase or other fabric to protect the transfer during ironing
Step 2: Make Your Transfer
- Select your image and use image-editing software to size it to 8"x10.5"
- Make any changes you might like, such as writing new stories and adding new pictures
- Flip the image on the horizontal axis so that the text will be in the correct direction when the image is transferred to the fabric. If you don't have image-editing software to do this, there should also be a print option that will allow you to flip the image on the horizontal axis when printing (if there isn't text, you don't have to do this, but the result will be the mirror image)
- Insert the photo transfer paper into the printer according to the package directions (there may be a notch or something to indicate the proper orientation)
- Print the image on the transfer paper
Step 3: Getting Everything Ironed Out
- Cut your fabric to fit around the laptop, with extra for seam allowances
- Lay the fabric out flat on a hard surface (with some newspaper or something under it) and put the transfer paper on top of it. You'll want to leave about a 1.5" border around each edge and a 2" space between the two sheets
- Place the pillowcase over top of the two sheets
- Heat the iron (the transfers I used called for High heat and no steam, but make sure to check your instructions)
- Iron over the pillowcase until the surface is warm to the touch, this may take a few minutes. Be sure to keep the iron moving so you don't scorch anything
- Remove the pillowcase and gently peel back the paper backing on the transfers
- Sometimes the backing paper sticks, or not all of the transfer has affixed to the paper. Be sure to peel really slowly, and if anything is sticking, go back over it with the iron
Step 4: Sew It Up
- Position the fabric right sides (transfers) together so that the transfers are aligned however you want them to end up (I wanted mine centered)
- Pin along the two short edges and one long edge (basically making a big pouch). For nice corners, pin and sew them on an angle - this will make them slightly rounded when they're turned right sides out
- Sew these edges
- Roll over a seam along the open side of the fabric and pin
- Sew the seam
- Trim the seams down a bit if there's a lot of extra
- Turn right sides out
- Slide in your laptop
FIN!
Step 5: **A Couple of Tips**
- In order to make it easier to line up the transfers, try sewing the sleeve (Step 4) BEFORE ironing on the transfers (Step 3) - this way you can make sure they're properly aligned
- Try not to pin or sew the edges too close to the laptop. Since there will be seams inside when it's turned right sides out, you'll want a little extra space so that the sleeve isn't too tight
- Pin and sew the bottom corners at a slight angle. When the extra fabric is trimmed away, it'll make for really nice looking corners once they're turned out
- I opted to just make these sleeves, since both my mom and I used padded bags to carry our laptops. If you wanted to, you could add a layer of padding and lining
- Pinking shears would be helpful (I didn't have any though) when trimming down the seams, just to make sure that the fabric doesn't fray
- To make a neat seam on the opening, fold the fabric over, and then over once again. This will ensure both sides have a finished edge
- Make sure to use thread close to the color of the fabric for a neater finish
Step 6: **Updates**
To make a sleeve for a thicker laptop:
- In addition to a front and back portion cut to the dimensions of the laptop (plus seam allowances), cut a strip long enough to go around three sides and the width of the laptop (in this case, 34" long and 2.5" wide, plus seam allowances)
- Cut pieces of the same size in a lighter fabric (I went with muslin since the outside was canvas). If you want to add padding between the layers, you can do that - a sheet-type foam works best
- 3. Pin and sew the pieces together. The long strip will be between the front and back pieces, making a kind of fabric "box" (see 2nd image)
- Turn the outer fabric right side out, but leave the lining wrong side out. Iron your transfers onto the outer fabric - while you're at it, you may also want to kind of squish everything down a little and iron it as well (see 1st, 3rd, and 4th image)
- If you're using padding, slip it inside the outer fabric, and then put the lining in
- Tuck in both the outer fabric and lining along the top so that no raw edges are showing. Pin and sew along this hem (see image 5)
Finalist in the
Converse Back to School in Style Contest
SINGER Kids Crafts Contest
19 Comments
9 years ago on Step 6
I like the picture of Jack and Sally in front of Schloss Moritzburg :) Greetings from Dresden!
11 years ago on Introduction
I think i will make this for my girlfriend - Quick question for a man who knows very little about sewing and stuff: Is there a way to make this case more sturdy/padded? The only method i can think of is stuff it full of cotton. (Which might be good for doubling as a pillow-esc-emergcy thing.)
Reply 11 years ago on Introduction
Sounds awesome! If you check out the last step you can find some info about a slightly different sleeve I made for my dad's laptop which had some padding. I'd suggest picking up some sheet-type foam or quilt batting so that it won't be lumpy.
Good luck!
Hmm thanks - I don't know if i will have enough time to make it for christmas. plus i have to measure her laptop. It seems like a good gift because she just got a laptop.
Nice ible btw.
Thanks so much!
They really don't take long at all to make and make a great gift. Also, if you know specifically what type of laptop she has you could likely find the specs online and work from that - I'm sure she'd be thrilled.
I could just ask her and say i want to research the processor or something. I'll have to find that iron on t-shirt stuff. Is that common? Could i just walk up to the craft store and ask for it?
I've seen transfers available in craft stores and office supply stores - basically every one I've ever been in has sold them.
Cool! Ill probably go tomorrow.
12 years ago on Introduction
Very Very nice! (such a clever girl) Where did you find the picture of the computer specs? Makes it extra cool
!! You and your sister are sure cutie- patooties. I was wondering if somewhere in cyberspace there would be an actual copy of the front cover of a newspaper for the day your mom was born?
Reply 12 years ago on Introduction
Thanks so much! I found the circuit map online somewhere, but sadly I can't seem to find it again now. If you try putting things like "circuit map" in online, you might be able to locate something similar.
I have to agree, my sister and I were really adorable :) I wasn't able to locate a paper from the day she was born, but one of the modifications I made was to change the date on paper to be that date.
Thanks very much! My mom liked it a lot too!
Great instructable. i give a 10/10
Thanks so much!
Love that!
Thanks so much! I think it turned out really well. I hope my mom likes it too!
Very Cool !!!
Thanks!
12 years ago on Step 1
Hi mi dear shesparticular! In these days it is really great to listen to someone talking about a mother as you do... I really appreciate that! Could make some people believe not everything is hating and killing each other either physically or verbally... This Instructable is great by its content, but deserves like 500 stars for its intention... Lots of Light!
Thanks so much! My mom is pretty great :)
