Introduction: Survival Series: Improvised Water Mug
Addition 2 to the survival series! If you are lost in the wild, I am going to go on the presumtion that you have some survival knowledge, as you are reading this Instrucible, but anyways, if you were lost, and you had already built a shelter(see Survival Series: Shelter) and built a fire(see Survival Series: Fire and have found a water source, your not going to just start drinking it, your going to want to boil the water first, to eliminate bacteria and microbes that occur naturally in nature. No cup? Well, it must seem you are out of luck, my friend! But do not be discouraged, there are ways to hold your water! How you ask? Well, Let's find out!
Step 1: What Is It?
The answer, my friend, has many answer but the best one, if you are in that situation, you will need some thing to boil your water! The easiest way to do this, if you have it avalible, is to create a cup of bamboo! You might be thinking, Pshhht, bamboo?!?!? Well, you shouldn't be. Bamboo(grass) is naturally sigmented with a usual thick outer shell, perfect for holding water.
Step 2: How to Make It(option 1)
How to make this cup? Easy, if you have a knife! If you do have a knife, you will first cut a slice on both sides of the bamboo, to try to limit the strain on you knife, because this is one of your most important tools you will help you survive. Once you have the two or three cuts around the Bamboo, it will break of with a small to medium ammount of pressure. As I said in the last step, bamboo is naturally sigmented, which you can fasion into a makeshift cup. With your knife, you can(optionally) add a small hole near the top so you can use a small(BUT STURDY) stick to lift it out of the fire.
Having no knife on the other hand makes it a little trickier. You will have to break the bamboo by hand, so you will want to locate a weak stalk and try to break it through pressure. After that, it would help if you could find some sort of sharp object(stone, ect.) and try to carve a section out of the bamboo, or at least weaken it to help you break it with your feet or hands. Fill with water, place in fire, use two sticks to remove from heat.
TIP: The more live bamboo is, the longer it takes to burn
TIP: Make tea by adding White Pine Needles(comment if you need discription) which are an ok source for vitamin C
Step 3: How to Make It(option 2)
This is a option is a little easier to make, but the materials harder to find in a situation.
The thing we will be using in this option is heavy duty tin foil, which can be used to make a cup, but will take many layers if you want it to stand up to the intence heat of a burning fire. The only down side to this method to this method is having the tinfoil on you during the situation, which is why it is a good idea to keep it in a survival kit.
TIP: Good idea in a Rural Survival Situation, like if you had been robbed of all of your important things in your house(UNLIKELY BUT POSSIBLE) and only have the basics left, with nowhere to obtain more of any item.
Step 4: How to Make It(option 3)
This one will be the hardest to make, yet the materials should be easier to find. This way involves weaving thick banana leaves into a type of cup. Banana Leaves are easier(but still requires some energy), beacause all you would have to do with its wide leaves is fasion it into a cup shape and use thin widdled sticks to hold it together. Place near(NOT ON, or the leaves would burn through and the water would fall out) the fire and let it simmer to a boil.
Step 5: Hope You Guys Enjoyed!
Thanks for reading guys! I have used all of these methods to boil water, so if you are having trouble with them, JUST ASK!!!! I would love if you guys would leave a comment. RATE IT UP!
ALL METHODS CAN AND SHOULD BE ADAPTED BY YOU STANDARDS TO SUIT YOUR ENVIORMENT!
Survival Skills Challenge
3 Comments
10 years ago on Step 4
Till the water is not boiling the leaves won't burn, even if they are on the top of a fire-simple physics-the water drives away the heat-otherwise it is a good instructible ;)
yea. this was my friends work. we do instructibles together. check us out at youtube(same user) ill prob do an update it and add some stuff he didnt put in. but from my experence it does start to sortof burn to an extent.
Vote for it so i can win the contest guys!
