Introduction: SweetHeart Candy Surprise Box
You need a fun way to give someone special a valentine? Well, here's one way to do it! From colored paper and cardboard, to a small master piece that will make someone feel special!
- Colored paper
- Thin cardboard (shoe box)
- Colored permanent markers
- Pencil
- Glue gun + glue
- Scissors
Step 1: Cutting the Paper Sides of Your Box
Draw both sides of your box onto paper.
Cut two sides that are 1 by 3 1/2 inches . Then, two sides that are 6 by 1 inches .
Step 2: Cutting the Paper Body
Now cut two pieces of paper the size of 3 1/2 inches by 6 1/2 inches .
Step 3: Creating Your Fake Pull Tab
Now draw out and cut a tab that will fit the size of the width of the box. After that, cut a little rectangular indent and fold the corners.
Step 4: Tracing Your Cardboard Structure
Now that you have finished cutting your paper, place your pieces of cut paper on thin cardboard, and trace them.
Step 5: Matching Your Peices Together
Once you have finished cutting the cardboard, match the pieces of cardboard and the pieces of paper together in pairs as the picture shows above.
Step 6: Hot Gluing Your Paper to Cardboard
Now, squeeze hot glue onto the cardboard, and one by one glue the pairs together.
Step 7: Gluing the Pull Tab
Now, for the first part of the box, glue the fake pull tab onto one of the 6 by 1 inch strips of paper.
Step 8: Sketching Your Design
Before you glue more of your box, draw out the design for your valentine, so that it looks similar to this.
Step 9: Tracing Your Design With Marker
Once you have your design drawn out, take permanent markers and color over them with the colors of your choice.
Step 10: Adding the Pull Tab to Your Box
Now, hold both the pull tab section and the body of the box together, and glue them together. Do the same with the rest of the pieces.
Step 11: Gluing Your Full Box Together
When you have finished gluing everything together, look it over again, and maybe put extra glue in a couple of places where it is lacking glue.
Step 12: You Have a Finished Valentine!
Now that you have finished cutting, coloring, and gluing your box together, write a nice note or put anything of your choice inside the Sweet Heart Candy Surprise Box! 🙂
