Introduction: VHF/UHF HAM Mobile Antenna From Old TV Antennas
Weekend, I grab an old TV antenna amplifier trashed around, to boost up my V/U handheld-radio, and I did it from all scrabs.
Step 1: Easy Parts
Other than Cat50 caxial cables, these are only things we need.
Step 2: Attach the Telescop Antenna to PVC Albow
One hole and screw it. as I am not planning to leave this antenna outdoors, there is no concern for rain protection.
Step 3: Another Bigger Hole
Drill another hole to pass the cable and split it.
Step 4: Prepare for Soldering
To brush the negative mash out, and bind them together.
Ring the negative and positive ends, are ready for soldering
Step 5: Soldering and Tighting
This is simple, ugly but works, since it's first run, no need to be beautiful or fine finish.
Step 6: SL16 Plug Soldering
Simple too, perhaps everyone has different theory / technique of doing this job, I wellcome you post your experience and advice. :-)
Step 7: Gluing a PVC Pipe
No text here.
Step 8: Measure ROE and Test Run
As the VHF band wavelength has 2Mts, we need about 47-50cm of each side of the telescoping antenna extended only, the original TV antenna has about 75cm each, we need to leave one or 2 ranges in.
The ROE test wasn't ideal (2.81) after adjustment, I got about 1.3 reading. this is just fine to make a test with friends, unfortunately, these days here in the north of Buenos Aires Argentina, the band is quite desert.
Enjoy the DIY. 73
LU9DDD
