Introduction: Wired Gemstone Flower Necklace
Create this stunning focal necklace using wire and gemstone beads. We have used Carnelian and Tiger's Eye, but you may choose to use whatever stones/beads you like! We love this design as it allows a great deal of freedom - if you make a mistake or break the wire, simply wind on a new piece of wire and keep going! This design is also quite easy to master; once you get the hang of it, you could make this piece in an hour or so!
7x 25mm Tiger's Eye Faceted Drops
7x 14mm faceted Tiger's Eye oval beads
8x 12mm Carnelian Rice Beads
2x 10mm Carnelian Rice Beads
2x 6mm Faceted Carnelian Round Beads
1x 8mm Carnelian Round Bead
24ga Silver Artistic Wire
Fine Chain
Clasp of Choice
Step 1: Make Your First Flower
Use your 24ga wire and create the first flower as per the diagram.
Step 2: Second Flower
On this step you will be making the drop section that attaches to the first flower that you made.
Step 3: Double Layer Flower
This flower is similar to the first, however you will be making a double layer.
Step 4: Put It All Together!
On this step it is simply a matter of connecting all the pieces together to create your pendant. You can then attach it to a chain or leather to make it into a necklace.
