Introduction: Chain Bracelet
this is an easy bracelet and it is made of materials that you could find around the house.
Step 1: TOOLS
for this instructable you will need a little bit of chain, a paper clip (I used a colored one but you don't have to)
pliers, and small wire cutters (optional)
Step 2: Shortening Your Chain
use your 2 pliers to pry apart the chain link down to where it almost wraps around your wrist but is too short by about 1 1/2 inches
Step 3: Making the Clasp
take the paper clip and straighten it out and place your half done part of chain on your wrist then put your straightened out paper clip on your wrist and measure it between the two ends of chain with about 2 centimeters extra and then cut it. twist one end of the paper clip around one end link of the chain and make a small loop with a small opening just a good bit bigger then the wire of the chain so you can slip one of the links into the loop on the other end of the paper clip
Step 4: You're Done!
now the fun part...wear the bracelet!
