Introduction: Concrete Charcuterie Board With Live Edge Slab Inlay
This project is pure experimentation - I wasn't sure how it'd come out - spoiler - it was a decent success. But it was my second concrete project ever, and it was a step forward in advancing my maker skill set. I guess you could chalk it up to wanting to try mixing resources with the fact that I already had all the materials on hand.
Video is below, followed by step by step instructions.
Step 1: Gather Materials
Below is a list of everything I used for this project. It's not as bad as you'd think!
MATERIALS
- Quikrete 5000 (~1/5th of a bag) - I also recommend Quikrete Countertop Mix
- Melamine (for molding)
- Scrap MDF (for Log Planer sled - not necessary if you have a band saw!)
- Black Silicone Sealant: http://amzn.to/2zEOLHG
- Minwax Fast Drying Spray On Poly: http://amzn.to/2heLF1z
- Paste Wax (Any type)
- Mineral Spirits (Any type)
- Screws
- Masking Tape: http://amzn.to/2pygofL
- Container for Mixing Concrete (Use a big bucket!)
TOOLS
- RIDGID 13” Thickness Planer: http://amzn.to/2u7YrmK
- RYOBI Circular Saw: http://amzn.to/2q1l5wn
- RYOBI Power Drill: http://amzn.to/2q1l5wn with Drill Bits
- RYOBI 10 in. Sliding Compound Miter Saw: http://amzn.to/2q1klHw
- RYOBI Miter Saw Stand: http://amzn.to/2p1072e
- RYOBI Stationary Bench Sander: http://amzn.to/2q1Cq8k
- RYOBI Glue Gun: http://amzn.to/2uLJt7V
- Silcone Caulking Gun
- Cake Fondant: http://amzn.to/2haxI4R
- Any tools to vibrate the concrete: http://amzn.to/2q1l5wn
- BESSEY Clamps: http://amzn.to/2oIJGVy
- Hand Sanding Sponges: http://amzn.to/2oHa6pP
- Level (24”): http://amzn.to/2phF3Cj
- 12” Speed Square: http://amzn.to/2phZUIt
FILM / EDIT EQUIPMENT:
- Canon Rebel EOS T2i: http://amzn.to/2pwwlDI
- Main Lens: Canon EF 50mm f/1.8 STM Lens: http://amzn.to/2zt0jKR
- Secondary Lens: Canon EF-S 18-55mm f/3.5-5.6 IS II Lens: http://amzn.to/2pwmuhi
- USCAMEL Tripod: http://amzn.to/2hbbVdg
- Studio Lighting Equipment: http://amzn.to/2rtrkg0
- Rode Microphone: http://amzn.to/2oIExg3
- Blue Snowball Mic (VO Recording): http://amzn.to/2hd92sF
Step 2: Find Firewood, Build Sled
I found this old piece of firewood (Alder?) that was many years old and very dry and destined to be burned (Pics 1-2). I couldn't let that happen. Time for a fun live edge project (a first for me).
I used some scrap MDF and some wood screws to work up the simplest sled possible so that I could feed the log through my planer to start flattening (Pics 3-4). This was by no means the most efficient way to do this, but I don't have a band saw to mill lumber so this was my best option. Other options would be to just buy a small live edge slab, use a table saw jig of some type, or use a band saw if you have access to one.
Step 3: Mill Your Firewood Log
I made many passes through my planer with the log in one position (I'd say 25-30) in Pic 1 to get to a nice clean flat surface in Pic 2. Then, I could flip the log over and over again, making incremental passes (Pic 3) until I was happy with the thickness of the piece, which was roughly half an inch. I wanted both sides to be very clean so I could later pick which side I liked best to be featured. Then I squared up both sides carefully (Pic 4) on the miter saw and was left with a perfect small live edge slab (Pic 5).
Note - if I had a band saw - this likely would have been much simpler and I'd have wasted less time / materials.
Step 4: Final Live Edge Slab Prep
I wet and dry sanded down my piece up to 220 grit (Pic 1) and then applied a few coats of fast drying spray on Poly to my log (Pics 2-3) and sanded down to a smooth final surface. This was to water proof the slab so it wouldn't be damaged against the wet concrete. It is food safe once it dries.
Next, I pre-drilled (Pic 4) six holes, then inserted a few small screws (Pic 5), leaving me with a log that had screws in it Pic 6. These screws would serve the purpose of anchoring the log into the concrete so it was secured once the concrete cured.
Step 5: Making Walnut Legs
I had scrap pieces of walnut from a previous build that I wanted to use as the legs (Pic 1). I routed a chamfer on the edge (Pic 2), which wasn't very clean, so I cleaned it up on the belt sander (Pic 3). Easy enough.
I then cut my pieces to length in Pic 4, a length that was based on the overall size of my molding. It is purely subjective to how you do this step. I cleaned up the sides in Pic 5 on the disk sander to create perfectly even lengths, and then applied the same poly sealant like I did to the live edge slab in Pic 6.
I then did the same anchor screw method in Pics 7-8, leaving me with two ready-legs in Pic 9. I think they look pretty cool!
Step 6: Mold Prep - Part 1
Using the final size of my live edge slab (totally unique to your situation), I then cut a base and four sides for the base out of melamine to fit the slab (Pics 1-2).
Then, using hot glue (Pic 3), I built the molding. You can use screws here if you want to reuse the mold, but i find hot glue to be quicker, just as secure, and I didn't plan to reuse the mold.
Step 7: Mold Prep - Part 2
Once you build your mold, take paste wax and spread it around all of the corners of your mold (Pics 1-2). Then, using a caulk gun, spread black silicone sealant around all of the edges and corners of your mold (Pic 3). Using a simple cake fondant tool (Pic 4 - link to this product in Step 2), you can run the small circular end over all of your edges leaving you with really nice, rounded edges (Pic 5).
Once the sealant cures after about 30 min, you can go back and peal off all of the excess that it created (Pic 6). You are able to do this very easily due to the paste wax you spread out earlier. Once you've pulled off all the excess, go back with mineral spirits (I had a small amount in a water bottle - Pic 7) and wipe off all excess paste and clean up the mold.
This whole process only takes about 35 minutes (including 30 of drying time) - so don't be intimidated by it.
Now you're ready to cast!
Step 8: Concrete Casting: Part 1
I used my Speed Square (Pic 1) to measure 1.25" from the bottom to serve as an indicator of how high I should pour my concrete (again, totally subjective to your own build). I also checked to make sure the ground I was working on was level (Pic 2). It wasn't, so I later shimmed my mold.
Off camera, I also covered the TOP of my slab in painters tape. That way, the concrete couldn't get on the mold incase some got underneath (Pic 3). I also gathered all my materials to cash. I mixed Quikrete 500, water, and stirred up the mix in an hold laundry detergent container (Pics 4-6) and then poured in my mold (Pic 7).
OPTIONAL
Tape down your slab to the bottom of the mold using double sided tape.
TIP 1
Use a large bucket to mix concrete all at once - I had to do this 4 times to fill my mold entirely - and I know for a fact that each pour had different consistencies in the concrete.
TIP 2
If you're looking for a very fine concrete, you should look to get Quikrete Countertop mix or use a sifter to filter out the larger rocks of the mix. I wish I had done this, but it was a learning experience nonetheless.
Step 9: Concrete Casting: Part 2
Once I poured my mold, I shook the mold back and forth quickly to spread things out (Pic 1) and then used a tool to vibrate the bubbles (Pic 2) - you can use anything you have for this - a sander, a multi tool, etc.
Having checked before that the ground was not level, I knew to shim up my mold 1/8" on one side to keep it level (Pic 3).
I worked up a little contraption in Pic 4 that allowed me to suspend my two legs into the concrete while it cured. Just scrap wood and hot glue - and I was very careful to check that everything was even and square. I had put in a lot of work at this point - no need to mess up now! I checked for evenness in Pic 5.
PRO TIP
Your molding tops might not be level - MINE WERE NOT. You can see in Pic 4 how the right side has two pieces of foam to prop up the contraption. If your molding is not even like mine, your legs will not sit level in the mold and will cure at a slope, So check for this levelness ahead of time.
Step 10: Finishing and Clean Up
I let the concrete cure for a full two days.
Once it did, it was rather easy to break apart the mold and pull the casting out of the concrete (Pic 1). I then pealed away the tape eagerly to reveal a very clean live edge top (Pic 2).
I realized after casting that I should have taped off the sides too, but was able to clean up the sides really easily with a chisel in Pic 3. I then used some wet sand paper at 220 grit to sand down all of the surfaces and edges in Pic 4. I took my sweet time with this. The concrete wasn't fully cured, but was perfect for sanding down.
You can see in the close up of the pictures that there were bubbles and other imperfections. Three things would help prevent this:
- Better bubble vibration to get rid of air pockets
- Using a finder concrete mix
- Mixing concrete all at once in a big container
Pic 5 shows me finishing wiping down the surfaces and checking that the feet are level. SUCCESS!
Step 11: Finishing to Finish!
With the concrete sanded down and cured, the last step is to seal the concrete on top. Sealants aren't the cheapest, but I think Quikrete makes one for about $20 that is food safe. In the interest of time and money, I won't be showing that step, but directions for sealing concrete are very straight forward.
If you want to know any materials, tools, or have any general questions answered, you can check out the second step or contact me via my website, thecuttingbored.com and I would be happy to do answer them.
As always, thank you for reading! I would be so grateful if you could please subscribe to my Youtube Channel for future projects.
I put out videos every few weeks.
Cheers! Zach
