Introduction: Converting a Drill Machine Into an Angle Grinder/Metal Cutter:
NOTE:
Since the set-up is not like a complete manufactured one , i would recommend not going too hard on it.
I am not saying that it won't work great but for a longer life span, you should go slow.It will take a bit more time to cut than the actual angle grinder but then you are saving money too. :)
Step 1: "Easiest Way to Convert Any Drill Machine Into an Angle Grinder"
All necessary steps and parts needed are explained in the video.Please watch it till the end to understand it completely.
Don't forget protective gloves, eye protection glasses & ear protection.
link for channel with similar videos
Advantage:
- Money saving.
- 2 in 1 ie. revertible back to drill machine.
- Safe.
- You can also replace the metal cutter disc with a wood cutter disc by following the same procedure.
Build a Tool Contest 2017
