Introduction: How to Write the Best Essay in 6 Simple Steps
The next time you feel you need some essay help, follow these 6 easy steps to write the best essay each time. These 6 simple steps form the most important part of the essay writing process.
Step 1: Step 1- Introduction
An introduction is the opening paragraph of an essay that informs the reader about your topic and how you will discuss it. The introduction briefly summarises what you will be discussing in the essay. Thus to start with your essay, start by planning the outline of your essay and use this to write your introduction. If you find that you have changed your initial idea for your essay or have added extra information along the way, always go back to the introduction and adjust it accordingly.
Step 2: Step 2 - Body
The body of an essay is the part where you discuss your essay topic. A body consists of several paragraphs that each deal with one aspect of your essay topic. Each paragraph should flow into the next one in a logical manner. This helps your essay to make sense and makes it easy to read and understand. The body of your essay will also contain in-text citations at the end of each paragraph or sentence that you have taken from a source. This helps avoid plagiarism in your academic essays.
Step 3: Step 3 - Conclusion
The conclusion is the last paragraph of your essay. Basically the conclusion is a short summary of what you have discussed in your essay. Briefly mention your findings again to finish of your essay. The conclusion may not contain any new information and is merely a short paragraph used to end your essay discussion in a conclusive manner.
Step 4: Step 4 - Reference List
The reference list is a list of all the sources you have used to help you formulate your essay. This includes any sources you have read through when doing research, even if you did not use it directly in your essay. The list thus also includes a full reference to all the in-text citations used in the body of your essay.
Step 5: Step 5 - Revision
Go through your essay, read it from start to finish and make sure that each paragraph flows logically to the next. This is also the time to make sure that your introduction accurately reflects what is discussed in the body of your essay. It also helps to ask a fellow student, parent, tutor or lecturer to read through your essay for you, to ensure that what you have written is comprehensive and in a format that best portrays your information. Often when you are finished with writing an essay, you do not feel like reading it again, so it really helps if someone can read it for you and give you some insight on the things you might have missed.
Step 6: Step 6 - Edit
The last and most important step to complete before handing in your essay is to edit your work. After doing your revision you must implement all the changes suggested by the person who read through it for you and also all the changes you have seen that are necessary to make. This includes editing spelling and grammatical errors.
