Introduction: Knex Ph-57 Sniper Rifle
This is a knex rifle with,what i think, is a new trigger system...
Pros
good range(100+ FT)
safety
accurate
no broken pieces
true trigger
Cons
low fire rate(meh... slingshot guns are the only knex guns with a good range)
Here are the instructions, hope you enjoy ( :
Pros
good range(100+ FT)
safety
accurate
no broken pieces
true trigger
Cons
Step 1: Barrel
1.make two 2.make ten 3.make two 4.put together two of these 5.add these 6.make one of these 7.add these 8.put together 9.add these 10.add the middle 11.you should have this 12.add these 13.side view 14.blue spacers 15.add this 16.add it to the other side 17.add this 18.add two of these 19.the final result
Step 2: Everything Else
1.make two of these 2.add a rod 3.make this 4.make two of these 5.add the rods 6.make this 7.combine 8.get these 9.add here 10.and here 11.make this 12.put it here 13.the trigger 14.add a blue rod 15.combine 16.what it should look like 17.add another blue rod 18.add two blue rods 19.add the sight 20.the back 21.get these 22.make this 23.make this 24.also make this 25.combine 26.slide the combination on to the green rod 27.snap into place 28.start of safety 29.add tan clip 30.add metallic blue connector 31. add wheels for comfort 32.add rb 33.final result
Step 3: Assembly
sooooo easy
Step 4: Loading and Firing
I hope this helps
