Introduction: Self-watering Planter From Found Dresser Drawers
Love the idea of the earthbox but can't help feeling like sticking living things in giant blocks of plastic is somehow just wrong? Don't think much about plastic but highly allergic to ugly? Like finding something old and making it new? This instructable is for you.
If you want more details on why the basics are set up a certain way, there are plenty of great instructables both here and all over the web, so I won't reinvent the wheel in this one, but this should be everything you need to get up & running.
Not starting with a pre-built plastic container as the main housing means some extra steps, time, and care, but for me the final product is worth it.
Step 1: Gather Materials
Materials:*
- (3) found dresser drawers
***Before you get the other materials, take careful measurements and know what you're working with. The length and width of any drawer determines the size of the screen/basket(s) you'll need; the height of the bottom drawer determines the height of the ABS pipes, etc.
- 1 piece of 2" diameter PVC pipe (length should be the total height of all drawers stacked, or slightly longer)
- 3 pieces of 3" diameter ABS pipe (about 1/3 of the total height)
- 2 plastic baskets (or something stiff and porous enough to serve as a nontoxic, waterproof, weight-bearing screen)
- outdoor stain & sealant combo wood finish, or paint for waterproofing
- brush
- wood glue
- drill
- utility knife
- wire, string, or cable ties
- landscape tarp, opaque plastic bag, or river rocks
- potting mix
- fertilizer
- plant(s) or seed(s)
Optional:
- painter's tape (to prevent bleeding)
- tarp or old newspapers (for easy cleanup)
- gloves
- river stones or rocks (as one more layer between the soil & water reservoir, and as a topsoil cover)
- Leatherman (it just feels good)
*from the hardware store, .99 store, nursery, your local curb, or the Craigslist free section
Step 2: Remove Hardware & Bottoms
Remove hardware by unscrewing from the inside, and take out any nails that prevent the bottoms from sliding out. Pull out the bottoms from all but one drawer and set them aside for later.
Step 3: Stack, Glue & Sand
Sand the outside to get the surface ready for staining and end up with a clean, even coat. If you don't mind marks, found drawers without them, or decided to use paint instead, feel free to skip this step.
I used a cinderblock for weight while the glue set, since I didn't have large enough clamps, but anything heavy with a flat base should work. Wipe off any excess wood glue before it dries.
The original plan was to stain each one separately to prevent dripping/bleeding, but the timing was such that I needed to take up less space, so I ended up assembled them first and just using painter's tape instead.
Step 4: Stain & Seal
Lay down a tarp or old newspaper. Use painter's tape if you want different colors with clean lines between them, and brush along the grain until all areas are covered. Let the first coat to dry completely before applying another. While that's drying, you can switch to the drilling and cutting.
Step 5: Drill Holes & Cut Screen
Drill holes in all ABS pipes to allow the soil to pull water up from the reservoir without spilling into it.
I also used holes at the bottom of the fill tube instead of cutting it at an angle, only because the drill was out and it serves the same purpose of allowing water to flow into the reservoir.
I needed 2 baskets to fill in the extra length of the drawer, so I did the same (see photos) to both, cut down the edge, and laid one on top of the other. Yours may be a different length or from a different material, as long as it serves as a screen and ends up fitting snugly against all sides.
Use one of the ABS pipes to mark a spot for the overflow hole, then drill. This is to allow excess water to flow out, so your roots will never be water-logged.
Step 6: Cut, Connect & Attach the Insides
Set all pipes on top of the screen/basket bottom and trace around them with a marker.
Cut inside the lines to allow some space to help support the weight of the soil. Some designs only use one pipe as the wicking chamber and the others as pure support (uncut at the top), but I decided to try using all 3.
Use wire, string or cable ties to attach the wicking chambers and fill tube to the screen.
Once all drawers are completely dry and assembled, place the screen, wicking chambers and fill tube unit inside and layer with river stones or small rocks.
Step 7: Add Soil, Plants & Topsoil Covering
Fill at least halfway with potting mix.
Transplant something you already have, or follow the directions on the seed packet(s) to start something new. I chose these peppers since they were the most in need of room to grow.
Add more soil and enough fertilizer for the size of your container. Leave at least an inch from the brim for the topsoil cover, which could be a piece of landscape tarp, opaque plastic bag, or more river rocks.
Step 8: Soak It, Sit Back & Watch It Grow
Water the way you normally would (from the surface, not the fill tube) to give the transplant roots a chance to mix with the new soil and the fertilizer a chance to seep in. Give it a nice thorough soak for the first one.
After that, all you have to do is use the fill tube maybe once a week, watering until some spills out the overflow hole, sit back & watch it grow.
Get in the Garden Contest
36 Comments
12 years ago on Step 8
Beautiful! One question: I don't understand how the bottom is waterproof. It seems like the water is just settling in the bottom drawer, and that will rot the whole thing. Am I wrong, or do you have some sort of bottom catch for the water?
Reply 12 years ago on Introduction
I used an outdoor stain and sealant wood finish to help with waterproofing. See this comment.
Reply 2 years ago
I confess that I went through the photos about 6 times trying to figure out how it was waterproofed. If it were me I would just line the drawer with a piece of pond liner otherwise it could leak and if it had the true waterproof liner it in you could use it inside or on a screened porch or patio without worrying about it leaking and damaging flooring, etc.
But what a neat project and great tips on the pvc and rocks, etc.
Is the waterproofing foodsafe? I am not a stickler about stuff like PVC pipe and most plastics, but I did wonder about the sealant.
7 years ago on Introduction
Love this! Since the contents are quite heavy & drawer bottoms are invariably a flimsy piece of ply it might be an idea to strengthen the drawer base. I have always found offcuts of laminate flooring ideal for the job.
What should someone worry about if owning these? if I dont plan on harvesting anything will the water cause any damage over many years?
9 years ago on Introduction
What's the purpose of the river stones sitting in the wicking cups and porous screen?
10 years ago on Introduction
Is there a specific reason to needing a porous screen to hold the soil above the water (the plastic baskets)? I am not sure what the benefit of having it porous is over just using a solid sheet.
A porous screen allows for some airflow, but as long as there's something for the plant to wick water from (like the pipes), it might be fine. You could try it with a solid sheet and report back...
Thanks for the reply. Looking into it more the other reason I found was so that if there was too much water in the soil it could drain out through the screen.
Actually, there's an overflow hole in this one - see Step 5.
10 years ago on Step 8
This is great, and I see people throwing away broken desks and chests of drawers all the time, so I can create some great wood planters. Thanks!
One thing I learned elsewhere that would work here: Instead of needing the plastic mesh and pipes down in the bottom, you can save time and work, and recycle some plastic drink bottles. Just drill small holes all over three sides of each bottle, cut a slit (about 1 by 3 inches) in the bottom, keep the original lid ON. Make as many of these as you need to lay into the bottom of your planter. These serve to "self-water" through your main pipe to the soil's top just as well as the mesh-and-cut-pipes do. I tried this with one large fig tree and it worked splendidly.
Wood can't hold water like bucket. It would be good idea to hide some pot in inside of wood so it will loo nicer. :)
Agreed. It would've been more practical to use a rectangular bin that fit perfectly inside, or let the bin determine the size and configured the wood as a shell around it, but the peppers still thrived.
You could use eaves-trough for the water storage. Cut it to length, cap and seal the ends, and treat the rest of it as you would a double bucket or double rubbermaid solution. For wider containers just do the eaves-trough in multiples and use a T or X pipe fitting on your watering tube to split the input pipe so it flows into the multiple troughs.
You can also use different width eaves-trough, it comes in 4 - 10" widths.
It's fairly cheap to do, and would let you keep most of that moisture off the wood. Would also let you customize to almost any size/shape of wood container.
I'm planning to try this using a long window box style planter on my front deck - it gets lots of sun and is quite dry so having the self watering container will be key for growing the planned tomatoes and cucumbers.
11 years ago on Step 8
Like it, and thanks for doing something that allows us to reuse, recycle and reduce!
12 years ago on Step 5
Could you have used galvanized "hardware cloth"? Its a fencing item like chicken wire that comes in a 1/4" or 1/2" grid widths.
Reply 12 years ago on Step 5
I thought about that for the screen, then did some research, and galvanized metal leeches into the water over time - I'm not sure how much time or in what quantity, but I decided against it since these are edibles.
Unique idea!
