Introduction: 3D Illusion Dot Mandala Painting Without Using Stencils
I tried this style of painting for the very first time. Hope you like my work and my tutorial :)
All steps cannot be explained in detail since there are lot of elements in Mandala painting. I have uploaded a detailed video in youtube which I have linked here.
If you're not very clear with the pictures feel free to hop on there to watch and learn this beautiful art.
Acrylic paints
Nail art stylus as dotting tools
Base surface such as canvas/mdf base
Colors:
Fevicryl - Lemon yellow, golden yellow
Flash - Orange, Violet
Camlin - Permanent Light blue
Step 1: Prepping the Base and the Mandala Measurements
The centre design is 4cm in radius.
Total size of the painting 18*18 cm. Once X axis, Y axis and the diagonal lines are laid down mark 70 degree and 110 degree across all lines. Hopefully I conveyed correctly :P
The base color of the painting is Violet
Step 2: Center Design
The trick for 3d illusion is for every petal the centre dot should be larger in size. It should be placed in such a way that it is from increasing to decreasing size to the centre
Also I have partitioned the 4cm radius circle with 1cm again.
Once the flower is completed design three rows in white
Step 3: 1st & 2nd Band Designs
First dotting 2 rows of Blue dots
Then drawing petals shaped dot patterns and again lining with 2 rows of Blue dots.
I had made 2nd band to be thin with small petal swooshes
Step 4: Final Band & Corner Design
Here again I'm giving 2 petal designs with slight variation.
For the Corner I had mimicked the centre design
Hope you liked my work. If you like my work please follow me here and also my youtube channel by SUBSCRIBING :)
Happy dotting
