Introduction: DIY Rainbow Loom!
Here’s a simple project that will keep you busy for around 20 minutes! This Rainbow Loom is called Heartbeat and if you do it you’ll see why!
You will need:
8 pink bands
8 yellow bands
8 green bands
8 blue bands
16 white bands
A hook
A loom
A c or s-clip
And a lil bit of happiness!
Have some of mine if you need it :)
8 pink bands
8 yellow bands
8 green bands
8 blue bands
16 white bands
A hook
A loom
A c or s-clip
Step 1: Getting Started!
Stretch a white band across 2 pegs and twist it in the middle. Place a pink band on top of the white band. You don’t need to twist the pink band. Pull the white band from the left side and pull it over the pink band into the middle. Then pull the right side of the pink band over to the left peg. See images.
Step 2: Finishing First Color!
Pull the white band from the right side over the pink band into the middle. Then pull the top pink band from the left side onto the right peg. Stretch a white band on top of the pegs. Pull the top of the pink band on the left peg into the middle. Repeat on right peg. You finished the first color! Yay!
Step 3: Next Color
For the next color (yellow in my case) you basically repeat step one and two. After you prepare the yellow or next color, pull the pink band over (see picture)
Step 4: Finishing the Bracelet!
For the rest of the band, repeat steps 1-3 with each next color. To finish the bracelet, use 2 white bands to secure the last color. Voila! You’re finished! Happy looming!
