Introduction: Cold Porcelain Clay Recipe
I was wondering about polymer clay substitutes and decided to experiment with homemade air-dry clays.
This recipes is very fast and easy to make, not to mention inexpensive. There's no need to bake either.
The things that can be modelled from cold porcelain clays are incredible. Its possible to sculpt finer details than polymer clays. Objects dry to a light-weight, stone like texture. Try it and see where your creativity takes you.
Step 1: Ingredients You Need
1 cup cornflour (optional try using rice flour 50:50 mix)
3/4 cup pva (wood) glue
3 drops of eucalyptus or nutmeg oil (for a preservative)
either 1 teaspoon baby oil or 1/2 tsp petroleum jelly (to prevent cracking during drying)
1/4 cup water
(New Recipe! update here, no cracks! How to Make Cold Porcelain Beads)
Step 2: Cook Ingredients
Ensure there is plenty of ventilation or wear a mask. Take care not to burn PVA as it may be toxic.
This will take only a few of minutes to form into a round mass.
Mix cornflour with water until free of lumps. Stir in pva glue and oils. Blend until smooth.
Stir on very low heat until the mixture forms first into a sticky glue then a thick ball. (Around 9 minutes)
The texture should be quite sticky. Once you roll out on a board or sink bench top, everything will come together. If the texture is rubbery and difficult to mold into thin petals it seems the clay has gone past redemption and is totally unusable and needs to be chucked in the bin.
I experimented with trying to recycle the rubberised mixture and after 72 hours soaking in water it softened and returned to a soft, pulpy mass.
Step 3: Recipe Tips
Wearing gloves you then need to knead the warm clay until it is smooth texture as in the video and picture below. I try not to add too much flour (after cooking) as the dough became sticky.
Test the texture of your cold porcelain mixture - you should be able to press its nearly paper thin - great for making leaves and flowers.
Tips:
* Wrap in cling wrap and store in an air tight container immediately after finishing making the clay to prevent drying out.
* Can keep up to a month. If frozen can be kept indefinitely.
* Do not store in fridge or it will harden too quickly to be used again. Steam to restore hard cold porcelain clay for easier blending with a softer batch. I noticed less cracks on drying.
* Cooking utensils shouldn't be used for food again for safety.
* The less water you add the less likely your sculpture will crack or shrink. Some recipes are 1:1 with cornflour and glue ratios.
Step 4: Colouring the Cold Porcelain Clay
I used food colouring here.
Later I shall experiments with acrylic and oil paints and varnishing with acrylic gloss mediums.
A cold porcelain clay producer site recommends adding colouring when you need it and storing coloured cold porcelain clay may be detrimental to it. The reason is until a cold porcelain clay sculpture is waterproofed with varnish - once soaked in a bowl of water it will return to the gluey mixture before cooking.
Step 5: Leaf Sculptures & Colouring Techniques
Here are some experiments with the hard + soft mix. Next time I'll make a soft batch only for the flowers. I have a penchant for roses!
First I scribbled on a bit of cardboard with some coloured pastels then brushed them onto the flowers. This technique is great for faces to create subtle makeup effects.
Step 6: Experiments With Hard and Soft Mixtures
Here is a recent test using one very firm mixture cold porcelain and a softer mixture.
The firm batch was mixed with a soft batch and kneaded thoroughly. Afterwards, the test piece hardened and did not crack.
With the softer batch there was a huge crack where I'd stuck on extra pieces for muscles.
* Knead thoroughly and smooth with a bit of water before use, to ensure there are no cracks. One tiny crack will eventually shrink into a huge crack.
* Cold porcelain clays tend to shrink to 15%-30% in size.
* Its recommended not to sculpt solid thick pieces as they tend to crack. Envelope thinner sheets around an armature eg squashed ball of aluminium foil or wire armatures padded with aluminum foil or other light-weight materials such as styrofoam or cardboard.
Step 7: Fixing Cracks
* Fixing cracks - dab on a bit of pva glue into crack. Add on a suitable size of cold porcelain clay to fill the crack - I used the soft batch, after a couple hours the large cracks mended perfectly.
* Some recipes recommend using handcream for smoothing and modelling. Then say if more than 2 tablespoons added the mixture may go mouldy. I found that water to smooth joins works well. So I would leave out the handcream.
* During sculpting, keep extra pieces covered to prevent drying out.
* Add a tiny bit of pva and water mix to help smooth joins and additional pieces together
* Small pieces dry in around 8 hours to a floppy texture. Larger pieces may take longer.
* Experiment with wire armatures covered with cloth tape for added strength.
* I found that my thinly rolled flower test pieces cracked less than the sculpted heads I'd formed and addition facial muscle pieces began to crack at the joints. Next time I'll use pva glue to smooth the joins properly.
Step 8: Making Armatures
This is a visual tutorial on making hand armatures.
Using the finest wires possible you can find, wrap them in double-sided sticky tape. I watched the Ardman method of making plasticine characters and they use cloth tape. I find that double-sided sticky works just as well.
The wires will stick together easily. Roll thin pieces around the wires for the fingers. I used a stick dipped in water for a mini rolling pin to sculpt and mold the clay below.
The pictures are easy to follow. With the different hardness' of cold porcelain clay there was problems with cracking with the softer clays. I can only conclude that less water is best for a clay mix.
I've also included steps for modelling hands without armatures.
Step 9: What You Can Do With Cold Porcelain Clay
I shall put up some examples of my experiments soon. In the meantime here are some lovely examples to enjoy. Notice when the porcelain clays dry there is a glassy appearance.
Rolling Techniques
My next instructable will be about how to make buttons using cold porcelain clay or playdough clay. The wonderful thing about cold porcelain clay is that it can be rolled very thin and even pulled through a pasta machine while sandwhiched between two pieces of plastic eg. acetate or contact paper might be a good idea. I'll put up some flower examples that I've been working on soon.
Check out this instructable for drawing and modelling tips which will help greatly with creativity.
https://www.instructables.com/id/How-to-draw-anything/
I love the downloadable e-books, (several free) about flower making using cold porcelain clay videos from the Thai Flower Art company which produces gorgeous artificial flowers. Clear high quality videos available showing how to make leaves and flowers. Also how to colour your cold porcelain clay tips. A great resource.
86 Comments
1 year ago on Introduction
Some of my experiments with this sort of thing have given me these ideas that might be helpful to your projects using air-dry clay: The "netting" from bags of lemons, garlic, etc. is useful as "re-bar" when making something that is flat and a bit large. I place the netting in the mid-section of my project and cover it with the other half of the cement or clay, trimming off any excess around the edges after my project is cured completely. It's proven to work wonders so far. One more thing, I use mineral oil as a softener so the clay doesn't crack when drying. A safe dye for clay is the coloring one uses for frosting (Wilton makes great food coloring for cake decorating). It does prove to be a bit messy - the cake decorating food coloring stains everything but at least we know it's not toxic! :)
Thanks for the great information and for sharing your experiences - so I don't have to experiment the same ways, you saved me a lot of time and trouble!
Peace!
3 years ago
its not free if you have to pay to down load
5 years ago
looks like fun :D
8 years ago on Introduction
Why on earth would you want to cook this? My guess...too much liquid. At the Studio we use what we call "CFC". (cold fusion clay) 1/2 cup PVA, 1 cup cornflour (corn starch) 1 tbs+ Boiled linseed oil, and 1 tsp salt. Mix to desired consistency adding water via a spray bottle or to thicken, a little more cornflour. This stuff air dries in 24 hours depending on the thickness or sooner in an oven a around 100-125 degrees in a couple of hours...again thickness is a factor. We don't have any problems with cracking. Add moist toilet paper, shredded and soaked brown paper bags and even chopped fiber glass insulation for strength, never poses a problem. These extra components are mixed in with a Kitchen Aid Stand Mixer with the paddle attachment. Just a bit or positive assistant to make your artistic quest a reality...
Reply 7 years ago
Thank you so much for telling us how to do (basically) the same thing, sans cooking. I have absolutely no plans to put toxic fumes in the air with my two children at home. I appreciate your input!
Reply 5 years ago
Hi, could you tell me if you need to varnish this when your piece is completed, so as to make it durable?
Many thanks,
Adriana
Reply 5 years ago
I've found CPC is Durable when dry but not waterproof, pieces left in sun on window seal are extremely rocky hard, five years later
Reply 6 years ago
Anddddd.............its the same thing that is in the glue you are using.
Reply 6 years ago
Bet his makes better clay though
You can easily make cold porcelain without cooking. But there are no toxic fumes to worry about as far as I know, unless heating the white glue somehow makes it toxic.
For a simple, easy cold porcelain you can make with your kids, try this recipe:
1 cup cornstarch
1 cup school glue
2 tbs white vinegar
About 1 tsp Nivea hand cream
Mix together well and knead until smooth and elastic, adding more starch or glue if necessary. Wrap it tightly and store in an airtight container. You can add a little white tempera paint or Wilton White White to it if you like, to give it a white colour when it dries. Otherwise, it will be translucent and kind of yellowish if left uncoloured.
I forgot to mention, the school glue is not as strong as the wood glue, so your clay will be much softer and may not hold it's shape very well. At least, that was my experience. Good enough for simple projects, but not for larger or more intricate ones.
Oops, I forgot an ingredient too: 2 Tbs baby oil (or cooking oil)
Reply 6 years ago
Finally someone who knows what they are doing, thanks.
From what I see the main difference is how these two products set. The cooking sets this recipes or at least allows it to do so in the air. Your recipes needs the boiled linseed oil to do the same. I would be cautious about using your recipe because it has boiled linseed oil in it. When linseed oil is "boiled" what is being done is catalysts are being added to make it cure faster. These catalysts typically are heavy metals that can be toxic. That is why cutting boards are usually done with unboiled linseed oil if they use linseed oil at all. It takes weeks to cure but it is food safe.
Hi, can you please tell me whats PVA. i m from India.
Reply 7 years ago
Hi Selve! - PVA is like fevicol what you usually use for all arts & crafts work in India.
PVA is the common abbreviation for Polyvinyl Acetate. It's the principle component in White Glue, Carpenters Glue, School Glue, PVA Glue, Wallpaper Adhesive...even used as Envelope Adhesive. Hope this is helpful,
Thanks.
I have tried both cooked and uncooked cold porcelain. I found the cooking produced a much stronger clay that was easier to work with and held its shape well. This method is preferred by many well known CP artists, such as Marisol Romero.
What you describe seems to be something quite different, as there is no glue in it and it can be dried in the oven (not generally recommended for CP). I have never tried adding paper or any other fibre to CP, and I have never seen it done in all the tutorials I have read. I'm not sure, but I don't think it would work very well. It is also not necessary. It's plenty strong enough on it's own.
5 years ago
Hello ,
My name is kathrin and i'm new using cold porcelain.
How do you prevent cracks on cold porcelain? do you use any oils or such to have cleaner looking figurines while working on your figurine?
would like to get some info which i can't manage to find really.
