Introduction: How to Make Earring Hoops in 2 Ways
I would like to show you how to create the earring hoops in two ways, one without a bail and one with a bail., similar to the bricks stitch earrings I created. Choose how you would want your earring hoops to be, get ready with a pair because I'll be sharing soon how to weave my brick stitch earrings using any of these earring hoops.
Materials & Tools:
18 or 20 ga wire
Wire cutter
Round nose pliers
Flat nose pliers
Step 1:
Depending how big you want your earring hoops to be, cut a 20ga wire and using your nose pliers make a loop at one end.
Step 2:
Using a round object, a mandrel or a spool shape the wire into a circle.
Step 3:
Using the tip of your flat nose pliers, bend the tip of the wire and cut off excess wire.
Step 4:
You can slide in a bead and insert the tip of the wire back to the loop. You're done!
Step 5:
If you want the earring hoops with a bail, rather than bending the wire in Step 3, wrap the wire just below the loop then cut off excess wire. You're done! You now have your earring hoops with a bail.
I have published a PDF file available for the earring hoops without a bail and you can download it with this LINK
