Introduction: How to Make a Paracord Keychain
Learn how to make a Paracord Keychain. The Paracord supplies you will need: about 3 feet of Paracord, a key ring, small scissors, a lighter or mini torch. You can make a 2 color Paracord by melting 2 pieces of paracord together. After you complete this keychain, try adding a flatline or tracer to it. Once you have you paracord keychain supplies, go to the next step.
Step 1: How to Make a Paracord Keychain - Step 1
First attach the paracord to the key ring, like in the picture. Notice the paracord ends point in opposite directions. you can make the loop as long or short as you want, leaving about a inch loop on the end. Then fold the Flatline in half and put it in between the knots.
Step 2: How to Make a Paracord Keychain - Step 2
With one piece of paracord, being it across the front horizontal, about a inch below the key ring.
Step 3: How to Make a Paracord Keychain - Step 3
Now bring the second piece of paracord over the top of the first, behind the back and up through the hole made by the first piece.
Step 4: How to Make a Paracord Keychain - Step 4
Keep repeating this paracord weave, lay the first piece across, bring the second piece over the top of the first piece of paracord, around the back and through the hole.
Step 5: How to Make a Paracord Keychain - Step 5
Continue the weave, always laying the same piece of paracord across the front. Until you have around a inch loop of paracord on the end left.
Step 6: How to Make a Paracord Keychain - Step 6
Now that you have the loop at the end the size you want. Just cut the paracord ends as close as possible, them melt them. Now you know how to make a paracord keychain, Check out the Viper and Sidewinder Paracord Bracelet. check out the Paracord Blog.
5 Comments
Tip 9 months ago
it's easier to do the middle cord if you pull out hte strands inside.
Question 2 years ago on Step 4
What knot is used to attach the paracord to the key ring?
6 years ago
This tutorial is missing key information. It skips steps and does not include information on how to finish the keychain. Had to look up other Cobra paracord tutorials to find out what to do with the end pieces. I managed to make one, but no thanks to these instructions. This tutorial is not for beginners and should probably be labeled as such.
Poor.
Reply 6 years ago
"Now that you have the loop at the end the size you want. Just cut the paracord ends as close as possible, them melt them."
Apparently this is your first time making a paracord project. They all pretty much end the same.
8 years ago
video please
