Introduction: Miss La Sen 4 Petal Lotus Lantern
You can make the lotus lantern to hang in the temple, house. It is very interesting.
Step 1: Download This Pattern to Trace on the Art Paper or Foam. Print It in A2 Size Paper.
Step 2: Cut the 2 Brackets Like the Picture
Step 3: Cut the 4 Petal and Bottom Bracket Like the Picture
Step 4: Cut the Top Bracket
Step 5: Cut 4 Corners of the Top Bracket Like the Picture
Step 6: Punch 4 Holes on the Top Bracket
Step 7: Cut the Gap in the 2 Brackets
Step 8: Place Two Brackets Into a 45 Degree Angle Like the Picture.
Step 9: Punch 4 Holes on the 2 Brackets Like the Picture in Order to Insert the String to Hang the Lantern Later.
Step 10: Punch 4 Holes on the Oval Shapes
Step 11: Insert the Top Bracket Into the 2 Other Brackets Like the Picture
Step 12: Use the Glass Paper to Glue on the 4 Oval Shapes.
Step 13: Insert the Bottom Bracket and 4 Petals Like the Picture.
Step 14: Insert the Arrows on the Top Bracket Into the Holes of 4 Petals
Step 15: After Insert 4 Arrows Into the Holes on the 4 Petals.
Step 16: Outside of the Lotus Lantern.
Step 17: Use the String to Hang This Lantern.
Step 18: Download This Pattern for Miss La Sen Shape. Print It in A4 Size Paper.
Cut the elements and glue them together. Then insert it under the lantern.
