Miss La Sen Lotus Triangle Bottom Lantern By jourlele in CraftNo-Sew362Introduction: Miss La Sen Lotus Triangle Bottom LanternBy jourleleFollow More by the author: About: like to make craft, cartoon More About jourlele »You have the lotus lantern with 2 layers, 6 petals. It is very simpleStep 1: Download This Pattern. Print It in A2 Size Paper.Step 2: Trace on the Art Paper or Foam. Cut the First Layer and the Second Layer.Step 3: Punch 3 Holes on Each Layer to Insert the Arrows Like the Picture.Step 4: Use the Glass Paper to Glue on Each Layer.Step 5: Insert the Arrows Into the HolesStep 6: Use the Zinc String to Insert Into the Bottom of the First Layer.Step 7: Insert the Zinc String Into the Bottom of the Second Layer Step 8: Cut the Excess StringStep 9: Punch the Holes on the Top of Each Petal for the Second LayerStep 10: You Should Insert the Arrows Inside Like the Picture. It Is More Beautiful.Step 11: Use the String to Insert Into the Holes on the Top and Tie Them Together. Step 12: You Can Cut the Top Bracket to Insert Into the Holes on 3 Petals of Second Layer.Step 13: Cut the Sepal to Glue Under the Lotus Lantern.Step 14: Download the Pattern for Miss La Sen Shape. Cut the Elements and Glue Them Together. Put Miss La Sen Under the Lantern
