Introduction: #Picassomania: Jumbo Painting Kit!
It is always good to challenge our skills right? So here i have come up with an Instructable to challenge myself to do painting with a Jumbo painting kit:
Painting Brush
Colour palette
And during most times in lockdown, i have been doing some painting to de-stress myself!
This is possibly something that could be made by anyone, on their own!
Step 1: Supplies : Painting Brush
Supplies, not restricted. And you could use any material of your choice, for any design.
Common supplies:
- Strong glue
- Cutter
- Scissor
- Acrylic colours (or any other material to colour for finishing)
- Crayons
Paint Brush:
Brush part of modern broom
Any thread(to make outer layer for brush)
Aluminium layered sheets (to create grip surface in brush)
Cardboard pieces
Strings
Jute thread (for body part of brush)
Stick (Here i used plastic stick to act as holding part)
Metal strings, metallic impression on the grip layer
Step 2: Painting Brush : Outer Layer : I Used a Jute Thread to Roll Over the Stick
Step 3: Painting Brush : Outer Layer : Tie the Jute Thread to the Other End of the Stick, to Keep It in Place
Step 4: Painting Brush : Outer Layer (you May Use Strong Glue, If Required)
Step 5: Painting Brush : Metal Layer for Grip : Add a Folded Cardboard Sheet to the Back of the Aluminium Layered Sheets
Step 6: Painting Brush : Metal Layer for Grip : Glue at the Closing Side of the Folded Cardboard Pieces
Step 7: Painting Brush : Metal Layer for Grip : Glue at the Backside of the Folded Cardboard Pieces
Step 8: Painting Brush : Metal Layer for Grip : Fix Them to the Backside of the Aluminium Sheets
Step 9: Painting Brush : Metal Layer for Grip : Tie Thin Metal Strings, to Create Metallic Impressions on the Grip Layer
Step 10: Painting Brush : Brush Part : Trim the Broom Brush Part, to the Required Size
Step 11: Painting Brush : Brush Part : Glue the Metal Layer for Grip, to the Brush Part
Step 12: Painting Brush : Outer Layer : (Optional) You May Use Your Choice of Colour Coating to the Jute Layer
Step 13: Painting Brush : a Close Look!
Step 14: Supplies : Colour Palette
Common supplies:
- Strong glue
- Cutter
- Scissor
- Crayons
Colour palette:
Colour balls (to make slots in palette for various colours)
Multiple colour tapes
Chart papers
Thin plastic strips
Cardboards
Salt paper (smoothing edges of the plastic balls)
Step 15: Colour Palette : Base : Draw the Outline(of Any Design) With Pencil, Onto the Cardboard
Step 16: Colour Palette : Base : Stencil the Main Layer
Step 17: Colour Palette : Slots : Slice the Plastic Balls, Into Halves Across the Centre
Step 18: Colour Palette : Slots : With Pencil, Draw Outline of the Plastic Balls Onto the Base
Step 19: Colour Palette : Slots : Cut the Part(s) of the Slot, From the Base
Step 20: Colour Palette : Apply Colour to the Cardboard Layer
Step 21: Colour Palette : Finished Colouring!
Step 22: Colour Palette : Smoothen the Edges of Sliced Plastic Balls, With Salt Paper
Step 23: Colour Palette : Glue the Plastic Balls (turned Into Slots) to the Cardboard Base
Step 24: Colour Palette : Outer Layer!
Step 25: Colour Palette : Inner Layer!
Step 26: Colour Palette : Adding Eyeballs, Like Structure!
Step 27: Painting Brush : Making an Additional Thin Brush, for Writing Purpose!
Step 28: Colour Palette : Adding Additional Support, for Keeping the Base Straight!
For additional support to the base cardboard, i have used a strip cut from an unused plastic hanger.
1. I cut the bottom part of an old cloth hanger.
2. Unsmoothened the strip at edges, so as to glue it with the base cardboard.
Step 29: Colour Palette : Hollow Cardboard Cylinder, to Hold the Base Cardboard in Hands!
In order to hold the base cardboard in hands, i have used a thin hollow cylinder cardboard structure wrapped with black colour tapes so that it is alike with the base cardboard. Glued it with the base.
Adjusted the hollow cylinder, to a dome like structure to make it fix with the flat base.
This is used to hold the Colour palette with hands.
Step 30: And Finally!
Here's the jumbo painting brush and colour palette, that could be used for painting purpose!
Step 31: Going Outdoor, to Paint!
Step 32: The Output!!!
![Super-Size Speed Challenge](https://content.instructables.com/FGT/7AOV/KBP339SF/FGT7AOVKBP339SF.jpg?auto=webp&crop=1240%2C600&frame=1&width=320)
