Introduction: Schwag Jacket Reclamation
Many heavily branded companies produce millions of dollars in schwag every year in the hope that unsuspecting giftees will become walking billboards.
This NFL Superbowl embroidered jacket was special-ordered from VF Imagewear, Inc. The underlying jacket retails between $133 and $165 as its Force APX Jacket.
Having no love for organized sports, so a simple mod makes this wearable.
Unfortunately, embroidery is difficult and time consuming to remove. When you do, the underlying material has been substantially weakened by the original embroidery, so you will not be able to have it re-embroidered.
You will need:
1 schwag jacket/gym bag/t-shirt/sweatshirt, etc
1 Iron-on
1 Iron
5 minutes
You will need:
1 Iron-on
1 Iron
5 minutes
Step 1: Apply Patch
Position patch.
Secure with cellephane tape. This is less likely to melt than other tapes and will hold the patch in place.
Cover with cloth (here, I used a cloth napkin).
Step 2: Apply Heat
Use an iron on the highest heat setting.
DO NOT USE STEAM.
The dry setting will melt the adhesive to the fabric of the jacket.
A steam setting will help remove the patch, should you change your mind.
DO NOT USE STEAM.
Step 3: Optional Sewing
Using a thread color similar to the patch's boarder, sew a reinforcing stitch around the patch to better secure it to the jacket.
This jacket is water resistant, so the microfiber doesn't absorb the adhesive as readily.
The stitch will help make it last.
Step 4: Wear Your De-branded Jacket
The camera flash picked up the green nylon in the patch. In person, its much closer in color to the jacket's fleece lining.
