Introduction: Seaglass Necklace Pendant
Ever been to the beach and found a piece if seaglass? Do you know what to do with it? Make a necklace pendant!
Step 1: Gather Materials
All you need is a piece of seaglass, wire, and needle nosed pliers.
Step 2: Make the Necklace Loop
Take a piece of wire 6 inches long and bend 3/4 of an inch if it at a ninety degree angle around your needle nosed pliers, now you have a right angle. Bend the wire to make a loop around the pliers and a ninety degree angle facing the other way. Now wrap the rest of the short end of the wire around the other end of the wire.
Step 3: Securing the Seaglass
Wrap the wire around the seaglass until it is almost completely secure.
Step 4: Making a Swirl
The the wire down to about and inch left. Bend the very end of the wire over and pinch it with the pliers to make a tiny loop in the very end of the wire. Wrap the rest of the wire around it making a big swirl. Push the swirl down in an open spot on the seaglass.
Step 5: Making It Tight
Go on the back of the seaglass and twist the wire. Twisting it makes it tighter so the seaglass won't just fall out of the wire.
Step 6: All Done
Now you have a seaglass necklace pendant to show off to all of your friends.
