Unusual Uses Ziploc Bags
Intro: Unusual Uses Ziploc Bags
Resealable plastic bags are so useful at keeping things securely sorted. Though the organizational uses for this plastic pouched wonder are abundant, there's quite a few unusual uses for Ziploc bags that might surprise you. From paint to marinade, there's more than a few unusual uses for Ziploc bags.
STEP 1: Airplane Phone Holder
There are so many storage uses for resealable bags when travelling, especially when there's liquid limits to what you can take on your carry on. Carrying a few extra bags with you when travelling on an airplane is smart, since the bags can be used as a makeshift phone holder for your next flight.
When you're in your seat, place phone inside the clear plastic bag and seal closed. Open the drop down tray table in front of you and place the top of the bag into the tray lip and close the tape, trapping the thicker closing strip between the tray and the seat. You can close the locking hasp over the bag to secure everything in place.
When your phone is resting securely you can still use the capacitive touch screen, and headphones can easily puncture the bag into the jack if you want to watch a movie.
Some airplanes have different versions of the tray table, so you may have to adjust the method to suit your plane model.
STEP 2: Piping Bag
If you're ever in need of a piping bag but can't find one, chances are you'll be able to locate a sandwich bag that will serve the same function.
Scoop your frosting into the bag. If you can find a small bowl to wrap the open top of the bag over, that will make filling much easier. Spoon frosting into bag until about 3/4 full.
Seal the bag and use scissors to snip a small corner off the bottom of the bag. Squeeze the bag from the sealed top to push the frosting out the cut opening in the bottom of the bag. Pipe directly onto your cupcake or dessert. The bag can be refilled as many times as needed.
STEP 3: Funnel
Piping delicious frosting isn't the only function of filling a resealable bag and snipping off a corner. Using the same trick the bag can be used as an emergency funnel for dry good or liquids.
Depending of what you're funneling, and the opening size of the receptacle, you can cut off more or less from the corner to get the right flow for your application.
STEP 4: Marinade Bag
Staying in the kitchen, resealable bags are perfect for marinading food. The best part is that it keeps your hands from getting messy, and makes marinades a snap!
Simply put all your marinade ingredients into an appropriate sized resealable bag, seal up and mix with your hands until combined. Open the bag up again and place your food to marinade inside the bag. Lay the bag flat on the counter and try to remove as much air inside the bag as possible before sealing. Once the plastic bag is sealed massage with your hands until the food is completely covered with the marinate. Place in the fridge and let the marinade do the hard work.
STEP 5: Breadcrumbs
Ziploc bags are just so good at keeping a mess contained, that it's perfect for the next time you want to make crumbs from a cracker or stale bread.
Place your food into a Ziploc bag and start smooshing it with a rolling pin. If you're not gentle with making crumbs the plastic bag can split, so if you're unsure double wrap the food before turning into crumbs.
STEP 6: Keep Ice Cream Soft
Okay, the last kitchen use for Ziploc bags. I promise.
If you've even kept ice cream in the freezer for too long you might have noticed ice crystals forming on the top of your favorite flavor, this is called heat shock (or freezer burn). This happens when ice cream melts a little and then is refrozen, when the ice cream is put back into the freezer the container isn't air tight and the cold draws moisture out of the ice cream and freezes into large ice crystals on the surface.
The best way to combat this is to add an air barrier between your frozen favorite and the rest of the freezer, like in a large Ziploc bag. This provides a method to block air from moving around inside the container of ice cream but still let the cold through.
STEP 7: Store Paintbrushes
In the workshop a resealable sandwich bag can be invaluable for your next paint job. Between paint coat applications while the paint is drying on your next project it's also drying on your brush or roller. Instead of cleaning your brush between every coat and wasting water or mineral spirits just put your brush in a resealable sandwich bag, squeeze out the air, then seal to preserve your brush until you're ready for the next paint coat.
I've had brushes last overnight using this method, though haven't tested longer. I usually finish my paint jobs in a day so duration isn't as important as the short-term gain of not having to wash my brushes between coats.
STEP 8: Shower Head Soaker
Vinegar is great for descaling all kinds of things in your home, like your kettle or stainless steel water bottle. It's also great for use on your shower head to to descale the insides and increase the flow. You could remove the shower head first before soaking but by leaving it on you also expose the neck of the shower plumbing to the same treatment, double whammy!
The bag is placed over the shower head and filled until the head is completely submerged, the top of the bag is wrapped closed and secured with a zip tie and left to sit overnight. The next morning the tie can be cut and the vinegar can be poured into the drain. Let the shower run for about a minute after this application to blast out any remaining vinegar in the head.
STEP 9: Packing Airbags
An alternative to using paper wadding next time you ship something is to use airbags. If you're like me you reuse your resealable bags as often as possible. Before throwing them away for good, using them as packing fill is a great last use.
Close a resealable bag most of the way, then blow air into the small opening until bag is inflated and quickly seal shut while continuing to fill the bag. Once the air is trapped inside you might need a little tape to secure the seal and ensure it stays inflated. I find it easiest to fold over the resealable top and then tape shut, giving an extra layer of sealing protection.
STEP 10: Paint Project (for Kids!)
Kids love being creative, and messy. Allow them to express themselves with color without all the mess that comes with painting.
The best part of this method is that there's no rules with how you apply the paint, or make your creation. Any paint will work (though, water-based acrylic is best), and can work for any ability or age group.
These artistic masterpieces can be made by placing a piece of printer paper in a large Ziploc bag and then adding a few drops of acrylic paint, then seal the bag. Press your fingers, palm, or any other instrument against the bag where the paint is to smear it around and make your design.
After, clean out your Ziploc bag with warm soapy water and let dry, then repeat for the next project.
Do you have your own unusual uses for Ziploc or plastic bags? I want to see it!
Happy making :)
183 Comments
Gadget93 6 years ago
1) Fill it up with water then
2) Seal it
3) Bring it out into the sun
4) Use it as a magnifying device to focus the sun's energy into a single point thus creating fire from water.
BriannaV2 4 years ago
WhiteWolfM 5 years ago
Re: Packing. Don't use just air, recycle the packing peanuts from items you received. Its more polite to seal them up than to fill the box with them loose, and let the receiver pick them out of item nooks and crannies (or have a pet or young child find them, heaven forbid!)
And if you don't want to recycle used food bags, just use cheap dollar-store ones, small lunch ones to huge freezer bags!
PS: If your package has to pass customs, write a note on a sheet of paper:
" This item was well packed before inspection, so please return all the packing to the box, and reseal it properly? Thank You. "
I started doing this after Canadian/US Customs destroyed a few items due to not returning packing, and not re-sealiong a box properly/securely.
RFB-2 5 years ago
Thought I'd add a bit to the "unusual uses for Ziploc or plastic bags" presentation.
The Vacuum bag food savers are relatively expensive as are the storage bags so I use the following:
I
place the item to be refrigerated into a Ziploc bag, add a straw into
one corner of the bag (only a few of the plastic straws are on hand here
and will switch to the far more environmentally-friendly paper
variety’s very soon). I collapse the bag to the straw entry point and
aspirate (well, suck out) the air and at the same time finish sealing
the bag as I quickly pull out the straw. Works relatively well.
Wingletang 5 years ago
Great ideas! If you turn the bags upside down, other applications appear - see my Instructable 'Small Component Storage From Ariel 3 in 1 Wash Pods Box'.
gm280 6 years ago
You can buy really small size ziplock plastic bag in the 2" by 3" sizes. Those are great for sorting electronic parts like resistors and capacitors. I print out a label and slide it inside the bag with the sorted parts and can easily see what each bag has in it then.
dollywild 5 years ago
aunt margie 6 years ago
lbuser 6 years ago
Grocery stores, dollar stores, Costco, Smart 'N Final, Bed Bath and Beyond.
skylane 6 years ago
I got some at a "dollar store".
Some about 1 1/4" x 1 1/2" and
about 3" x 3". I'm sure each size was a life time supply. Great for dosing pills, vitamins, supplements. No clunky calendar boxes.
dridenh1 6 years ago
Walmart has the three small sizes in their craft section. So many come in one purchase that you'll never need to buy more! LOL!!
Alaskan Bev 6 years ago
Stores that sell geocaching supplies have them, too, or you can order them online from geocaching websites.
dragon flyer 6 years ago
Dollar Stores...
Celticlady1960 6 years ago
If you cannot find them at the dollar store, Michael's sells them in all sorts of very small sized in the Jewelry Making Section and they are often on sale
oky jim 6 years ago
you can get them at pharmacies and hobby shops. Try hobby lobby.
Was1x 6 years ago
pgs070947 6 years ago
Amazon.
I use a lot of them
Overlord_Laharl 6 years ago
check craft stores in the bead section. i get mine from michals.
https://www.michaels.com/2-in-x-3-in-resealable-zi...
http://www.michaels.com/1.5-in-x-2-in-resealable-z...
PattyP17 6 years ago
Walmart sell two or three sizes of very small ziploc bags in the craft section.
gm280 6 years ago
You can buy the little 2" x 3" bags at a lot of electronic parts stores and places like Amazon. And they also have other small sizes as well.
