Introduction: Venom Costume - Eddie Brock With a Symbiote - Puppet and an Extra Arm.
I wanted to be Eddie Brock from Venom... so i made a venom puppet out of a foam antelope head.
- Foam antelope head (deer head would work... or any chunk of foam)
- Plastic sheet for eyes
- fake hand
- Grey hoodie
- Spray paint.
- Foam Noodle and chunks of foam
- Black cloth
- hot glue
For tools i used
- heat gun
- laser cutter
- scissors
- band saw
- Dremel tool
- ... im guessing any maker could figure it out with the tools they have
Step 1: Making Venoms Head
- I used a band saw and Dremel tool with a rough sanding wheel to shape the head and cut in a large mouth
- Made hand pockets inside the foam head so i could use like a puppet
- cut a long tongue out of a pool noodle and shaped it with a Dremel tool and heat gun
- used a laser cutter to cut out teeth, shaped with scissors
- Lasered out the eyes out of a plastic and shaped them round with the heat gun to fit against the foam head
Step 2: Painting and Placing Teeth and Tongue
- I painted the head red and black with spray paing
- painted the tongue red, also added drool with drips of clear hot glue
- hot glued in the teeth after creating cavities in the gums with a Dremel tool.
- blocked off the throat with a piece of red cloth that had a little shading with a bit of spray paint.
Step 3: Creating the Arm, Hoodie and Venom's Neck
- I used a pool noodle to make an arm about the size of mine. I used a fake hand i happened to have sitting around
- used a strap of webbing to secure the fake arm around my neck and shoulder.
- Cut a hole in the top of the shoulder in the hoodie to let my real arm out.
- Made Venom's neck out of a sheet of black fabric that i hot glued into a tube. I secured the tube to the foam head
- We made black lines on the hoodie showing the Venom growing off of the sweat shirt.
Step 4: Wear It and Have Fun
Halloween Contest
