Install Node RED on Your Raspberry Pi
Introduction: Install Node RED on Your Raspberry Pi
About: Born in Austria. Began to learn coding in 2015. Passionate software developer ever since. Skilled at Javascript, PHP, C#, Java and C. Always excited to learn new things.
Node-RED is a flow-based programming tool for wiring together hardware devices, APIs and online services in new and interesting ways.
It provides a browser-based editor that makes it easy to wire together flows using the wide range of nodes.
In this tutorial I will show you, how to install Node-RED on your Raspberry Pi.
Supplies:
To install Node-RED, you need the following equipment:
Recommended:
Step 1: Setup
How to set up the Raspberry Pi?
If you download and install 'Raspbian Stretch with desktop and recommended software' on your Pi, Node-RED is already installed.
You can see how to start it at the end of the tutorial.
Step 2: Check for Updates
Type in this command to check for updates:
sudo apt-get update
Step 3: Download and Install NodeJS
First you have to find out which version of NodeJS you need. Type in this command to find out:
uname -m
If the response starts with armv6, then you will need the ARMv6 version. Otherwise, if it starts with armv7, you will need the ARMv7 version.
  1. Copy the link of the version you need from the NodeJS website
  2. Paste it after you type 'wget' in the console of your Pi
    wget [YOUR_NODEJS_DOWNLOAD_LINK]
    eg. wget https://nodejs.org/dist/v10.16.0/node-v10.16.0-linux-armv7l.tar.xz
  3. Press enter. NodeJS will now download
  4. After the download finished, extract the file
    tar xf [YOUR_DOWNLOADED_NODEJS_FILE]
    e.g. tar xf node-v10.16.0-linux-armv7l.tar.xz
  5. Navigate into the extracted directory
    cd [YOUR_EXTRACTED_DIRECTORY]
    e.g. cd node-v10.16.0-linux-armv7l
  6. Copy all files to '/usr/local/'
    sudo cp -R * /usr/local
Check if everything has installed successfully:
node -v
npm -v
Those commands should now return the version of node and npm. If they don't do that, you have probably downloaded the wrong NodeJS version.
Step 4: Install and Start Node-RED
Install Node-RED via the Node Package Manager:
sudo npm install -g --unsafe-perm node-red
After Node-RED has installed, you can start it with this command:
node-red
The response should be something like this:
Welcome to Node-RED
25 Mar 22:51:09 - [info] Node-RED version: v0.20.5 25 Mar 22:51:09 - [info] Node.js version: v10.15.3 25 Mar 22:51:09 - [info] Loading palette nodes 25 Mar 22:51:10 - [warn] ------------------------------------------ 25 Mar 22:51:10 - [warn] [rpi-gpio] Info : Ignoring Raspberry Pi specific node 25 Mar 22:51:10 - [warn] ------------------------------------------ 25 Mar 22:51:10 - [info] Settings file : /home/nol/.node-red/settings.js 25 Mar 22:51:10 - [info] Context store : 'default' [module=localfilesystem] 25 Mar 22:51:10 - [info] User Directory : /home/nol/.node-red 25 Mar 22:51:10 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable 25 Mar 22:51:10 - [info] Server now running at http://127.0.0.1:1880/ 25 Mar 22:51:10 - [info] Creating new flows file : flows_noltop.json 25 Mar 22:51:10 - [info] Starting flows 25 Mar 22:51:10 - [info] Started flows
The address of the server will be displayed in the response. (it's bold in this sample response)
Node-RED is now available at: http://[IP_OF_YOUR_PI]:1880/
You have now successfully installed Node-RED on your Raspberry Pi!
2 People Made This Project!
  • Puzzles Speed Challenge
  • "Can't Touch This" Family Contest
  • CNC Contest 2020
    CNC Contest 2020
DarrenA24
DarrenA24
3 days ago
Thank you for this well written Instructable! As I type this in August of 2020, nodered.org provides a one line bash script that will uninstall the old node.js and Node-RED and install the latest and greatest one. Just type it into your terminal and let it do the all the work. If this let's me add a link without thinking it is spam you will see a link next. https://nodered.org/docs/getting-started/raspberrypi
If not, type this into Google:
"Installing and Upgrading Node-RED" site:nodered.org/docs/getting-started/
