Introduction: Translucents Hollow Beads- Necklace
Sharing one way to create the molds for the liquid fimo hollow beads.
How to apply color and make them translucent
Step 1:
Materials used in this poject:
- Water
- Soft natural clay (potters clay)
- Silk stocking
- Cotton
- Toothpick
- Alcohol
- Alcohol markers
epoxy glue
- head pin
- bead cap
- chain
Step 2: Making the Mold
Mix water and soft natural clay to obtain a creamy liquid: Barbotine (ceramic slip)
Using a silk stocking and cotton make the bead mold
Dip the mold in the barbotine and let it dry.
It can air dry in a few hours, or in a few minutes if you use the heat gun.
Step 3: Liquid Polymer Clay Bead and Color
Once dry, cover the mold with a thin layer of liquid fimo and apply heat starting on the top
Apply a second coat and dry it again with the heat gun.
Apply color using alcohol markers and alcohol to obtain the translucent effect.
Make a new layer of liquid fimo and cure it. After that you can add a few more details with color.
Finish the piece with two more coats of liquid polymer clay.
Is important to work in a well-ventilated place.
By using the heat gun Fimo Liquid can release fumes
Step 4: Removing the Mold
Remove the toothpick and cut the silk stocking
Start removing the cotton from the inside. In this first phase don't remove the silk stocking, because it will be stuck to the barbotine To remove the barbotine and the silk stocking, dip the bead in warm water
Step 5: Finishing
You can put water inside the bead to create a more interesting effect (Optional)
Make the top for the bead with a small amount of liquid fimo (2 layers). Make a hole in the center and insert a head pin.
Glue it to the bead using epoxy glue.
Cover the top using a bead cap and mount your necklace.
Step 6: Have Fun!
Create new molds with different shapes and make more necklaces!! :D
Runner Up in the
Necklace Challenge
17 Comments
6 years ago
WOW! What can I say.....
6 years ago
This is absolutely beautiful, can't wait to try it out^^
7 years ago
What is liguid fimo
7 years ago on Introduction
that is... Amazing
I love it :)
Sandrartes
how neat, thanks so much--Karen
Thank you Karen!! :D
Thank you so much terriilyn, you are very sweet!! :D
really beautiful. so creative. you have more patience than I possess, clearly.lol
What a great idea.
Have you experimented with including LED lights?
Your experimentation reminds me of Tiffany glass in the Haworth Art Gallery in Accrington.
The work there took on a whole new life when illumination was included. It went from mind blowingly awesome to something that's so amazing it doesn't seem real.
Hi world of woodcraft! :D
Thank you for your nice comment! :D
I haven't tried it with LED lights, but I will!! :D
I'm sure that it will look great, Thank you for your suggestion!! :D
Hi Snowflakepixie77! :D
Yes it's possible to make them with any color. I like the idea of the acorn cap. I have a few acorn caps... I'll try one. I'm sure that it will look very cool :D
Thank you for the suggestion!!
7 years ago
Creative technique and very pretty necklaces!
Thank you traeger for your nice comment!! :D
7 years ago
These are beautiful. What a cool process. Thanks for sharing.
Thank you sellers.nathan!! :D
7 years ago
I love it can't wait to give it a try !
Thank you connie46!! :D
If you need help, just ask ;)
