121Views11Replies
Author Options:
220v led bulb array delay Answered
I made a makeup mirror with 15 holes for lights, now iwouldlike to have a slight ON delay from one to the other. I was thinking maybe a capacitor after each bulb or just a relay? ( figured the relay kind of has a 0.1 second delay)
iceng
iceng
2 years ago
One more circuit.
This only works with 3W lamps !
iceng
iceng
2 years ago
What 220 VAC light bulb are you using ?
turbiny
turbiny
Answer 2 years ago
cold white probably 3w if its too darki`ll go with 5w
iceng
iceng
Answer 2 years ago
3W at 220V DC is almost 13 ma DC.
Are we on the same page ?
iceng
iceng
Answer 2 years ago
Correction "almost 14 ma" actually13.6 ma DC.
turbiny
turbiny
Answer 2 years ago
i will be using normal bulb 220v AC E27 socket
iceng
iceng
Answer 2 years ago
If your leds run on AC you cannot use capacitors to delay.
You will have to use a ring counter IC and SSR relays to switch ac lamps..
turbiny
turbiny
Answer 2 years ago
thank you very much
just to be sure ? capacitors wont work even just for 0.1 second?
iceng
iceng
Answer 2 years ago
It is called a "chase light".. Capacitors only cause a phase shift on AC.
While it can be easily done using a combination of the three references.
In the end a microprocessor running opto triac isolators will be quicker to go.
Both need a wall wart power supply.
turbiny
turbiny
Answer 2 years ago
thnx a bunch but its to much work and$ unless there is a reay to run module in aliexpress .
i guess i will just wire them directly
thnx again very helpful
iceng
iceng
Answer 2 years ago
Just to see, a DC chase circuit, I had lined up.
This could be modified for a ramp up instead of a ring run.
But DC is required !
