10316Views16Replies
Author Options:
Batch Help(randomization)? Answered
Hello Im workin on a batch file and i would like to have help with with making Cmd randomize between two selected numbers Example: Random 1-10 Answer: 3
knex_mepalm
knex_mepalm
Best Answer 11 years ago
 Chromatica, There is a way to do that! Without that process down there.
So you want 1-10 eh? You can do this by forcing batch to pick a number between 1-10, type this on text and save as .bat and incorporate it into your stuff.
Ok follow me on this! It may take around 1 second to 1 minute to generate the number because there are over 32000 possible answers so be patient! I tested that it works!
@echo off
:ans
set /a ran=%random%
if /i %ran% GTR 10 goto :ans
if /i %ran% LSS 1 goto :ans
echo Batch chose the number %ran%
pause
As you can see GTR and LSS mean that if it is greater than 10 or lower than 1 it will regenerate the number until it is between those limits! IPlease read this!
Chromatica
Chromatica
Answer 11 years ago
It does take a little bit.
But thank you so much!!
account3r2
account3r2
Answer 10 years ago
One time i made a guessing game from that and it was 1-20, but it took about 3 min. to fine a number
roxlaurie1
roxlaurie1
1 year ago
Using notepad I need to create an 8 Ball Guessing game. An 8 Ball game was a toy
that when you shook it and looked at the bottom a message would appear. The game worked where you think of a question and shake the eight to get an answer by looking at the bottom of the eight ball (see picture).
orksecurity
orksecurity
11 years ago
From "help set":
%RANDOM% - expands to a random decimal number between 0 and 32767.
To get a number within a more limited range, use the remainder operation:
set /a a=%random% % 10 + 1
will set %a% to a value from 1 to 10. This will not be perfectly distributed since 10 is not an even factor of 32768, but it should be close enough for anything you're doing in a batch file. If you need more sophistication, learn a real programming language.
("help cmd", and help on the other CMD commands, is also worth checking when trying to understand what batch files can and can't do.)
Chromatica
Chromatica
Answer 11 years ago
Sorry but his works better
knex_mepalm
knex_mepalm
Answer 11 years ago
 Did you try it?
Chromatica
Chromatica
Answer 11 years ago
I tried both and his didn't come up with anything.
Yours deserved a best answer!
sourconcrete
sourconcrete
Reply 1 year ago
You can use orksecurity's idea but remember the double percent sign. for example:
set /a a=%random% %% 10 + 1
that worked for me
FierceT
FierceT
2 years ago
After reading the entire post out of a random search on the web I would like to help you all with the following command. "set /a var=%random% %% 9 + 5" All of you referring to this command have been using the following syntax as mentioned by Jasond51. "set /a var=%random% %% max + min" I'm going to just say it, this syntax is wrong. I admit I used this syntax quite a bit, but I got it from a different source which is not important here. After heavy experimentation I ran into what the first and second numbers really mean. Just try the following syntax...
"set /a var=%random% %% <range> + <starting number>"
When you act on incorrect incorrect information everybody is going to be confused and look for potentially odd alternatives.
Jasond51
Jasond51
5 years ago
OK so batch is not great at random numbers
the best and easiest way in my opinion is to do this set /a var=%random% %% max + min
however if you try to set your min to something greater than zero it will ignore the maximum number
to avoid this you can put it in a loop like this
:start
if %var% gtr 9 go to start
echo %var%
adrian.varga.370
adrian.varga.370
6 years ago
So I used the set /a number=%random% %% 40 + 5 but basically if you don't use 1 as the min number the number will go beyond the max for example using Min1 Max5 does from 1 to 5 but using min5 max10 it goes like 7,9 then crosses the max number... The language of BAT isn't the best..
AlvaWilliams
AlvaWilliams
7 years ago
:: pick a random number between say 0 to 19 or 1 to 20
:: take the hundredths of a second 0 to 99 from current time
set eddie=%time:~-2%
:: modulus doesn't like numbers like 08, it thinks it's octal, so knock off the zero
set first=%eddie:~0,1%
if %first%==0 set eddie=%eddie:~1,1%
:: make number modulus 20 to keep range 0 to 19 , so 99 mod 20 = 19
:: if you want 1 to 20 change the modulus to 19 and add 1 to eddie
set /a eddie=(%eddie%%%20)
echo number=%eddie%
pause
Prof. Pickle
Prof. Pickle
8 years ago
Guys, seriously. orksecurity has a much better solution. It doesn't take a million years.
set /a number=%random% % max + min
The reason it doesn't work in batch files is because of a simple over-look.
set /a number=%random% %% max + min
Or have you all forgot that in the for command you need double percent signs instead of singles?
AlvaWilliams
AlvaWilliams
Answer 7 years ago
random numbers easy
take the millseconds off %time% 0 to 99
then xor to get in your range
AlvaWilliams
AlvaWilliams
7 years ago
help
echo. space space space word space space word
echo word word
the spaces don't show why ?
how to cure it ?
El Mano
El Mano
10 years ago
set /a num=%random% / (32767 / %yourmaxnum%)
will pick a random number between 0 and %youmaxnum% (replace %yourmaxnum% with a number like 10, or else
set/a yourmaxnum=10
Thank you, Padlock.
TheBatchies
TheBatchies
11 years ago
You can do what knex_mepalm did, but that takes _forever_ to load. Not to offend him, or anybody, but, uh... There are no good ways, the most commonly used method is knex_mepalm's.
