148Views2Replies
Author Options:
Brushless motor not running,help needed..!!! Answered
I have Turnigy 2836, 2350Kv outrunner connected to Hobbyking 40A SBEC ,Rhino 1550mAh 3S 20c Lipoly Battery and a Hobbyking servo tester to control the motor .when i try to start it makes two beep sound, vibrates and turns off.it was perfectly running last time i checked .which components' fault is this???
and how to check lipoly's voltage and current?can i use normal multimeter?
thanks for the suggestion....
Willard2.0
Willard2.0
6 years ago
The ESC's are in failsafe mode. The ESC is seeing a throttle signal that is not idle. Try calibrating the ESC's, then turning them on.
steveastrouk
steveastrouk
6 years ago
You can only "check the current", when its connected and running the motor. What voltage have you got on the battery when the motor is connected ?
