91Views6Replies
Author Options:
Can I use charger of different volt than the battery? Answered
I have a charger of 4.8V and my lipo battery is 11.1V. Can I use this charger with my battery??
Vyger
Vyger
Best Answer 6 years ago
Think of voltage as water pressure. If you try to push 10 pound water pressure into a 40 pound pressurized pipe. It will come out not in. You need more voltage than the battery has to push a charge into it.
iceng
iceng
6 years ago
No
fahmed20
fahmed20
Answer 6 years ago
why is it? Can't I just use it? The voltage doesn't matter right?
pls help
iceng
iceng
Answer 6 years ago
Voltage is what decides which way current is going to flow.
So in you situation the battery will be pushing current in to the charger !
The reverse current will probably over heat a part of that charger as a minimum or explode a semiconductor and start a fire as a bad case..
steveastrouk
steveastrouk
Answer 6 years ago
No, it won't work.
Imagine you have two buckets of water, connected by a pipe. You put one bucket on the top of a ladder. Which way will the water want to flow ? UP to the top of the ladder, or DOWN to the one at the bottom.
