560Views18Replies
Author Options:
Does anyone have a new idea about repurposing an old ceramic toilet. I'm ot interested in another flower planter. Answered
Nate Cougill
Nate Cougill
Best Answer 6 years ago
1. You could remove the sides of the tank with a diamond cutting wheel on an angle grinder, and use the large flat sides as a hone for your knives.
2. use the float ball valve system to release rainwater capture on to your crops. Mount the tank below a cistern.
3. Use the tank as the chimney portion of the rocket stove.
4. The tank could be used as a hopper for adding dry material into a process, such as adding metal pellets to a foundry, or plastic pellets to a 3-D printer.
threeels
threeels
5 years ago
Final product. Remove tank from bowl. Plug center hole. Thread PVC and spigot through refill hole and seal with Goop. Fill tank from the top and you have a free-standing hand washing station. What I discovered was that the thread on the original refill unit is specific to flexible hose for toilets. So I couldn't reuse the original refill unit without having to buy a new flexible hose and then adaptors to fit the spigot. Threaded PVC wasn't long enough to protrude through the bottom of the tank. So I used an old, t-shaped piece of PVC, filed down the stem to fit, and sealed gaps with Goop. Not the most elegant solution, but in a non-pressurized water system it does work.
Wired_Mist
Wired_Mist
Answer 5 years ago
Nice ! hope you took a few Pics while you were making it, would be a good I'ble. Just so happens theres an unusual uses contest coming up :P
threeels
threeels
6 years ago
Thanks for all the great answers. I hate to select just one. My preference is a combo answer between reusing the float ball valve system to release water (I'm thinking of using it for an outdoor hand washing station) and making a outdoor seat out of the bowl. A couple of notes: 1) this kind of ceramic won't take heat and will probably explode, so no cool chimney for rocket stove (damn), and 2) it's a repurposed toilet so the fabulous punch bowl is out, except perhaps as a watering station for your dog.
Nate Cougill
Nate Cougill
6 years ago
perhaps a light fixture. Remove the bowl from tank, use a diamond cutting wheel to remove superfluous areas, epoxy a socket in place, pull wire, and use the tank mount and floor mount holes to hang it
sixsmith
sixsmith
6 years ago
How about a speaker enclosure? just use a TON of loose fiber to absorb the internal sounds.
Wired_Mist
Wired_Mist
Answer 6 years ago
that does sound pretty cool O.o
Might get some intresing Accustics :D
sixsmith
sixsmith
Answer 6 years ago
Yeah. . have you ever seen those big horn style speakers? I can't recall what they are called, but I wonder if a toilet has a proper profile for sound propagation. . sound is a wave, water moves in waves. . ..
Although initial brain picture when I first saw the question was just glue in two half circles under the rim, and affix a circular/oval piece of wood with the speakers mounted in it.
Nate Cougill
Nate Cougill
Answer 6 years ago
compression drivers :)
Wired_Mist
Wired_Mist
Answer 6 years ago
I was almost thinking Attaching a small Sub Woofer to the Drain of the toilet and let the sound move through it (like the horn you mentioned). Were you thinking the same thing?
sevinstraus
sevinstraus
6 years ago
I had a friend who used a clean one as a punch bowl. Sealed off the bottom, filled the bowl and tank with Drink.
He kept a ladle hanging on the rim, and when the punch bowl got low, you just flushed to refill
iceng
iceng
Answer 6 years ago
LOL
Apparently your friend found people to drink from it !
sevinstraus
sevinstraus
Answer 6 years ago
I was one of them! He had assured us that it had never been used as an active toilet, only as a punch bowl.
iceng
iceng
Answer 6 years ago
Tip my hat to you !
I sort of assumed that, though it is a disquieting emotion when I imagine being at that bowl party .... And that refill feature is top rate.
liquidhandwash
liquidhandwash
Answer 6 years ago
You have an interesting friend...
handycrowd
handycrowd
6 years ago
For those days when you've just got to go.......
Wired_Mist
Wired_Mist
Answer 6 years ago
LOL, Best Answer !!!
cerberustugowar
cerberustugowar
6 years ago
mail box at the end of the drive way for "junk mail"
tank part could be buried and filled with dirt, then plants like mint won't grow all crazy on you.
5 seconds of entertainment when you push it off something high
Wired_Mist
Wired_Mist
Answer 6 years ago
Junk mail, ROFL
Totally need to make a Flushing sound :D
cerberustugowar
cerberustugowar
6 years ago
Wired_Mist
Wired_Mist
6 years ago
Fish Tank !
Could always use it as a lawn ornament too ^.^
Vyger
Vyger
6 years ago
Drinking fountain
iceng
iceng
Answer 6 years ago
;-P
