117Views13Replies
Author Options:
How can I wire (4) white leds to a on/off switch with one resistor all power to (3) 3v cell coin batteries? in a circuit Answered
I seen a few youtube videos but none show how to wire four leds in a circuit ! will one resistor be enough? how to wire the main power switch to resistor & power source & led? anybody knows how to make this work
iceng
iceng
2 years ago
Forward voltage of 1 white LED = 3.2V... Three batteries make only 9 volts !
Four white LEDs in series are 12.8V... so you must do 2 LEDs 6.4V
Two sets of 2 LEDs each in series with a resistance of (9-6.4)/o.02 = 130 ohms
Click the pic to see the whole image..
GNOEL82
GNOEL82
Answer 2 years ago
can you show me how to wire with this set up?
iceng
iceng
Answer 2 years ago
Do not forget the LED has polarity !
GNOEL82
GNOEL82
Answer 2 years ago
I noticed the power switch is connect to both + ends? i thought the switch had to be connect one end to each + & -?
iceng
iceng
Answer 2 years ago
Same as the circuit schematic.
Trust Me and give me Best Answer
. . . . . . . OR
Take Randofo's very good and free LED lighting class
https://www.instructables.com/class/LEDs-and-Light...
An Old Electrical Engineer Speaks..
BETTER You could buy a set of ten clip cords, four NIB magnets and wire it up.-
6635_Br NIB.jpg6639_sw-OPEN.jpg6642_SW-CLOSED.jpg6643V&NIB.jpg6622_batt&r.jpg6627_Ovrview.jpg
iceng
iceng
Answer 2 years ago
The orange - yellow Banana
represents the Switch Open in one picture And Closed in the next picture.
See how the nickle plated NIB (Neodymium Iron Boron) magnets hold the three Batteries in series and provide the electrical path at the same time !
Click the pics to better see the whole image..
iceng
iceng
Answer 2 years ago
Yea, I didn't have 130 ohm resistors so I used 150 ohms instead..
I also didn't have white LEDs but used some UV 3.4 volt FWD LEDs instead.
Do You Trust Me Now ??
GNOEL82
GNOEL82
Answer 2 years ago
PRETTY COOL!! YES I TRUST YOU SIR, JUST NEW TO THIS AND WANTED TO BE CLEAR LOL THANKS A MILL!
GNOEL82
GNOEL82
Answer 2 years ago
THE POWER SWITCH ONLY TURNS ON & OFF THE SIDE THAT IS NOT LIT? THE OTHER SIDE JUST STAYS ON AS SHOWN.. CAN YOU SHOW WHAT IM DOING WRONG
iceng
iceng
Answer 2 years ago
Switch must disconnect the battery !
GNOEL82
GNOEL82
Answer 2 years ago
THX SO MUCH FOR TAKING TIME TO HELP ME WITH THIS!!!
GNOEL82
GNOEL82
Answer 2 years ago
thanks so much for the info! can you show me help to wire with this set up? because the leds will be located as shown n switch n battery
