12150Views4Replies
Author Options:
How do I raise 3.7 volts to about 5-6 volts? Answered
I have a battery that has an output of 3.7 volts, but that's too little for the project I'm doing. I need about 5-6 volts that I can work with.
I'm driving 6 arrays of 2 leds, powered by an IC that I've programmed (for what its worth).
I was wondering if there was an amplifier circuit, a step up circuit, a transistor, dc-dc converter, a surface mount Genie I can use to boost the power of my battery.
Community, I call for your aid!
.Unknown.
.Unknown.
9 years ago
This circuit worked surprisingly well for me:
http://www.simple-electronics.com/2009/09/3v-charger-project.html
Most of the parts can be found in old appliances, and the Zener diode can be substituted for 2 white LEDs (Cathode to ground though).
Puts out ~500ma.
Jack A Lopez
Jack A Lopez
9 years ago
There exist DC-to-DC converters intended for the purpose of charging one's mobile phone from a pair of AA batteries. The output voltage from this device is a a regulated 5 VDC, at I forget how much current, a few hundred mA I think, similar to the spec for a USB port, often with the same shape. The input voltage is whatever 2 AA batteries in series can supply, which would be something in the range from 2 to 3 volts.
A while back, ladyada wrote the seminal "Minty Boost" 'ible, which is basically the same thing, a regulated 5 VDC supply that runs from 2 AA batteries.
But it's a lot of work to build something like that when you can just go out and buy it on the street for like 5 USD.  I claim to have seen such things in in-real-life, brick-and-mortar stores, but the link below is, of course, to online retailers:
http://www.google.com/products/catalog?hl=en&q=energizer+aa+phone+charger&cid=3577228618442524243&os=sellers
iceng
iceng
Answer 9 years ago
Ladyada and I both selected the MAX756.... !
iceng
iceng
9 years ago
This Maxim should do what you want.   A
