10616Views8Replies
How do you make this plastic bottle to plastic string device?
I found this on YouTube, but I could not find an Instructable about how to make it. Has anyone else found out how to make this device. I wish I knew Russian but there does not appear to be instructions on how to make it.
5 years ago
6 years ago
Turn on the captions and then select the translate option.
6 years ago
can someone make an ible for the device Alejandro uses?
http://vimeo.com/68808011
6 years ago
Somebody, design one that can do 5-gallon buckets!
6 years ago
https://www.facebook.com/media/set/?set=a.10150423...
https://www.instructables.com/id/Recycling-a-PET-bo...
Answer 6 years ago
The end of the video shows how he did it. Apart from the ring and bow it seems very self explanatory.
Answer 6 years ago
Interesting.
I may never again need to buy string for my weed wacker.
6 years ago
0:00In this video I show you how to cut the rope from plastic0:04bottle will tell you how to do butylkorez 2.0 and demonstrate0:08several methods of application of shrink properties0:11rope from plastic bottle.0:13As you can see, the new design butylkoreza favorably0:16small dimensions of ease of manufacture, and most importantly0:20ease of use. Now there is no need0:23no pre incise tape or press the bottle0:26the blade second hand. The new design makes it0:29itself, need only a bottle and one arm. Furthermore,0:34new design allows butylkoreza cut tape0:37different widths without moving blade. This machine I chop0:42tape width from one millimeter to one centimeter.0:46Very thin ribbon is easily confused with fishing line.0:48I use it successfully on the Donkey. Fish up to two pounds0:54break such a scaffold could not ....0:59Upon heating tape and sealed using a shortened1:03This property is easy to make a free plug-in connection1:06virtually all parts. This connection is the1:09firm of proven me. Note1:12- Even without half goats details of poles and tape1:15bottle of surprisingly strong and can withstand dynamic1:19my weight load. No screws, nails and even more1:23are not capable of. Shrink pulls items worse1:27bolting. Lately I've been increasingly1:31use PET tape as a temporary clamp. Loop1:35of such a tape can withstand the monstrous load anywhere1:37not shift, slide, and besides it is not a pity.1:41For example, drill hole 55 mm at an acute1:45angle to the surface without the use of polyethylene terephthalate tapes1:49I did not succeed. This tape is a good thing and all1:53time finds new applications in agriculture.1:58PET tape winding handle hammers and axes protect2:02them from chips and dents. Over the years, pliers pliers2:06and other protective tool handles falling apart,2:10winding handles such tools PET tape2:12will be more durable because PET2:15is more resistant to low temperatures and UV light.2:19All it takes to make such butylkoreza2:22Snip it sill or corner, the blade from the clerical2:26knife, two nuts M5, M5 stud or a piece of wire2:31(Thread on it can be cut separately) and wood2:35brusochek - strut. In pruning sill need to drill2:39Through bolt hole M5 so that2:42it coincided with the opening in the mounting hole2:45blade for stationery knife. Then, departing from2:49drilled hole on the nut width do2:52cuts in the corner of different depths. Depth of cut2:55will limit the width of the tape. All items are ready2:59butylkorez left to collect. For this we need to invest3:03channel in the blade and the holes in them to pass a3:06pin or wire and if you have a channel, then Strut3:10nuts sill wall, and if you corner, then tighten3:14nuts one wall bracket. To zanevolit3:17the second end of the blade insert wooden butylkorez3:19spacer. All you now have access to an infinite3:23reserve rope. And now you have a lot of bottoms3:27and necks of bottles. How to cast from their various3:30Part I will cover in one and the following video, but first3:34Fit video about making bilateral rings3:37coins. If you liked the video3:40and you want more, look at the other videos on my channel. They3:44not worse. Separately recommend my3:46video about making a bow made of PVC pipe.3:49And not to miss the new video - subscribe3:52the canal. Since you shared experience Lawyer Egorov.
