14153Views2Replies
Author Options:
How to polish/buff polycarbonate (lexan) on roughly cut edge? Answered
I'm not talking about minor scratches. I would like to polish 1/2" thick cube that I cut out with table saw, it's not transparent at all on the edges (due to rough cut), but I'd like it to be :)  Can I do it with some kind of Dremel attachment?
bratanpfred2
Answer 7 years ago
Wow Impressive!!! Thanks for the info!
IlirT
2 years ago
you cannot flame polish polycarbonate. polycarbonate = lexan
you will have to sand lexan, rout it, or polish it with a buffing wheel
once polished you cannot glue a polished edge or it will craze.
this is true of most plastics except plexiglass
The only plastic you CAN flame Acrylic = plexiglass
as seen here flame polishing lexan is a mess (see what happens at 1:45)
CaseyT10
3 years ago
this is the little butane torch I used. From Harbor Frieght tools. And the fishing lure I touched up the edge of the lip.
I also included a picture of my test lexan. One side was heated just right...while the other was just a little too much heat.
CaseyT10
3 years ago
I know this is an old topic, but I just wanted to add this incase anyone still looks for this information.
I have 1/8th inch lexan. Making fish lure diver lips. I tried sanding and polishing. That didn't work. So after reading this forum, I tried something.
Sand the edge flat with 240 grit sand paper.
Wet sand with 600 grit sand paper.
Use a small butane torch and quickly touch up the edges. Only allowing a tiny amount of heat to graze the lexan. After a few passes, you will start to notice your edge turning clear. Let the lexan cool for about 10-20 seconds, and give it a few more passes.
Afterwards, I used a dremel polish pad and some Meguiars plastX clear plastic polish.
All done!
My project took about 2 minutes all together
