8115Views15Replies
Author Options:
ITS URGENT! Arduino not working with external power supply? Answered
I have made arduino uno u3 robot, i have used 2 geared motors via a l293d using one 9v battery and tried power the arduino with a 9v battery, then with 9v adapter but it did'nt work, I also tried powering the board via the Vin pin, also through the usb cable using the 9v batterg and adapter, but it didnt work either.when i plug it to the laptop with usb everything works very fine. Please give me a sol. soon urgent i hav the exhibition after 3 days!!
PatelM18
10 months ago
i have made8 channel relay control with ir remote by arduino board -with laptop usb power supply project working ok -but if i give power by 230/5v dc power source or i phone mobile charger 250v/5 v dc(1 amp). project misbehave like when i press remote button 10-12 time then one relay on or off - then i found if i touch my picker in my hand or any mettle peace to 0v dc then it work fine -if i remove picker or metal then again missbehave .
any one have solution for it .
FancyChanciePatelM18
Reply 4 months ago
Did you solve this?
I have the same problem. and have gone over the project many times looking for crossed or incorrectly placed wires.
steveastrouk
4 years ago
So the UNO is still working on USB ?
a 9V battery isn't likely to run the thing, and the motors.
What did you use for the 9V adapter ?
Show your circuits.
Steve
Ankan Nayaksteveastrouk
Answer 4 years ago
it only and only works when i connect the board to the pc via usb cable.
if i try to power it with a battery through the usb jack, it doesnot work.
the adapter is simply a regulated 9v supply from a rectifier.
the motors are connected from l293d, with 6v regulated power.(on bread board)
the servo is connected on the breadboard.
i have made the ground common for all..
plsssss....suggest me something...
instrctables is not letting me upload a pic..sry.
steveastroukAnkan Nayak
Answer 4 years ago
Can't help without a diagram, sorry.
DON'T POWER IT THROUGH THE USB JACK !!! Not with a 9V supply !!!!!
RJK6steveastrouk
Answer 2 years ago
I have same problem as Ankan but with 6V instead of 9.
I made a arduino car robot with arduino uno (shields on it), sharp IR-sensor, 2DC motors, 4AA battry and 2 limited switch.
When I connect the arduino with the cable, it works fine! all the functions work and I don't see any errors. However once I try to let it work through external power supply (4aa) it doesn't work at all. The power light lights up but that's it. I think I would need to use resistor for each limited switch but I have no clue which resistors I should use and I am not certain if it will solve this problem either. Please help me because I am getting so hopeless. Thank in advance.
PS - I tried this method but it seems like it's not working at all
V = R * I, or solved for R, R = V / I
R = 6 volts / 0.030 amps
R = 200 ohms --> 220 resistor
my breadboard are based on this fritzing sketch (the code is made by me and it works without a problem)
https://killerrobotics.files.wordpress.com/2015/06/robot-part-1_bb.png
https://killerrobotics.files.wordpress.com/2015/06/robot-part-2_bb.png
steveastroukRJK6
Answer 2 years ago
Show me a circuit diagram, not a pretty picture. The usual problem is missing a ground somewhere.
TheElectromania
3 years ago
I have noticed same with my nano V3. The sketch works perfectly when it is connected through usb by pc or using a mobile charger adapter with USB connection.
As soon as i power it using Vin pin and ground with regulated 12V supply or even a 9V battery, it works crazy i.e. the sketch is not running at all.
As soon as i again power is through USB jack, it works perfectly.
this is very strange... any clues.. suggestions ?
TheElectromaniahrithikbansal70
Answer 3 years ago
I had make mistake in wiring as mentioned in my earlier post.
Just check...sometimes we very simple mistake due to oversight.
TheElectromania
3 years ago
I solved the problem.
i noticed that by mistake i had connected a resistor between ground pin of my nano and ground of my powersupply.
i removed it and now it works perfectly.
rickharris
4 years ago
Just a small point - The 293 will only power small motors - about 800MA then it automatically cuts off. This gives the appearance that it isn't working.
I aghree with the others as well.
steveastroukrickharris
Answer 4 years ago
That fact alone is likely to kill his 9V battery. "For the want of the nail"
Pazzerz
4 years ago
An Arduino Uno can be powered by
  • a stable (regulated) 5V DC, which you can either supply via the USB power lines, or via the shield connectors, or
  • an unregulated 6-20 V DC (7-12V recommended), which you can supply via the 2.1 mm centre-positive barrel plug connector.
I would not recommend using a 9V battery, because its voltage will drop quickly, but in a pinch this can be used.
ref: http://arduino.cc/en/Main/ArduinoBoardUno
steveastroukPazzerz
Answer 4 years ago
Absolutely, and there is very little chance the 9V battery will run motors anyway.
