96Views15Replies
Author Options:
Is This supposed to show Up Like this?(VIDEO INCLUDED)? Answered
I have Installed Windows 7,In the Personalize Area When i Click Windows Color It opens The Old Windows Color And Appearance Dialog(See PIC 1)When It should Open something different(See PIc 2) Just Look at The Pictures and the Video Also,I Tried The Registry Entries To Force Aero To work,But it does not,I already tried a restart. Does Anyone Here Have Experience in this Field?
Madrias357
Madrias357
11 years ago
Hate to say it, but your best bet would be to kick up your video-processing capabilities if possible. I know it's a pain, but sadly, Microsoft is trying to market products to force us consumers to change everything over and spend lots of money. If you're using a desktop, turn the system off (have to say it in case others look at this with the same question), remove the panel, look at the motherboard first to see if either nVidia or ATI has a chipset on the board. If so, you'll have to use that brand or any other except the other (ATI will not work properly on nVidia boards and vice versa). As I doubt you're a gamer (90 MB of Video Memory isn't a lot), a video card of sufficient power to run Aero shouldn't cost a lot. Also, take note of whether your desktop needs an AGP or a PCI-E type card. I don't remember how they look anymore (haven't dug around in mine for a long time and I don't have PCI-E slots anyway), but you don't want to buy the wrong card, open up the box and the electrostatic bag, go to put it in and be confronted by the evils of not having that slot. Sorry for the long reply and the assumption you are using a Desktop.
ReCreate
ReCreate
Answer 11 years ago
Well,No,Its a Laptop. I read That there what a Registry Entry That Control's this. I am Not a gamer,At least not Mostly. I have Build 7100 By the Way I want a way To force Aero To work,Even if it trades Performance.
Madrias357
Madrias357
Answer 11 years ago
Well, unfortunately, I can't help you then. I know as much about laptops as I do about the oceans. In other words, virtually nothing. Though, to force Aero to work, try messing w. your power settings first. Search for something, anything, that might turn off Aero on battery. Had something similar on a friend's Vista where it would shut Aero off while running battery-only.
ReCreate
ReCreate
Answer 11 years ago
Ah,Ok,Thanks.
ReCreate
ReCreate
11 years ago
I want a way to Force it to go on,And i will See How it goes after that. Does anyone know how to do that that is still valid For Build 7100?
NachoMahma
NachoMahma
11 years ago
. What happens if you type "themecpl" into Start:Run... (or Win 7's equiv)?
ReCreate
ReCreate
Answer 11 years ago
It says That it can't Find themecpl,Make sure you typed the name Blah blah blah.
NachoMahma
NachoMahma
Answer 11 years ago
. You need to enable Aero. I have no idea how to do that. Google is your friend.
ReCreate
ReCreate
Answer 11 years ago
Google Finds Ancient stuff,things that are no longer valid for windows 7
dombeef
dombeef
11 years ago
Does it affect the way of how windows work.If not deal with it
ReCreate
ReCreate
Answer 11 years ago
That's The Most Stupid And Useless Answer Ever,You Fail,You fail at failing.
I am Sorry If you are having a bad day but today i am just Pissed off at everyone and everything.
dombeef
dombeef
Answer 11 years ago
OK look does it make the colors different or does it change it back to the old way?If Not deal with ok?
ReCreate
ReCreate
Answer 11 years ago
It does not do nothing,No matter what i change in there it does nothing to the Way everything appears. But if it did open the Other window,Like in the Second Picture i should be able to modify the appearance. I have 90 MB of video Ram By the way.
dombeef
dombeef
Answer 11 years ago
The ram does not make a diference but what you should do is reinstall winblows
ReCreate
ReCreate
Answer 11 years ago
Ahem,I did That 2 Times. By the Way,This is A fresh install,I installed it The day before yesterday,And since the First day it always was like that.
