633Views17Replies
Author Options:
Is there a simple way to be able to run low voltage things like LED arrays from the mains power? Answered
Basically I want to be able to make some LED lights to light up my workbench in my shed and it'd be easier if I could just plug them into the wall instead of having to replace batteries every now and again.
pandyaketan
pandyaketan
10 years ago
I have made many LED projects on AC Mains... They are very simple, but after much research...Hope they help.
reg
ketan
Damp Cuttlefish
Damp Cuttlefish
10 years ago
just use a transformer. you get ones that plug straight in to the wall that go as low as 1 or 2 volts
seandogue
seandogue
11 years ago
For the USA, !N4002 diode in series with LED in series with a (nominally) 33K resistor yields about 5mA. Diode block the negative going part of the sine wave, 33K is voltage-dropping/current-limiting to prevent the LED from seeing excessive voltage. a 1N4003 or 4004 would be necc in countries where the mains are ~220VAC and the resistor would have to be upped in value as well.
iamdenteddisk
iamdenteddisk
11 years ago
umm- "wall wart" a step down transformer was designed for this because leds only consume 1.6 volt so the rest of the mains voltage would need to restrained by a resistor that would be in an un-real price range for a resistor rated at 400Watts or more also it probably be bigger than a desk and emmit allot of heat. this is why we step down the voltage first then construct a circuit with LED and current limmiting resistor.
jacob2910
jacob2910
11 years ago
you can buy a down converting battery pack we use them at school they can go down the 3v and up to 24v
pyroten
pyroten
11 years ago
You could go buy a step down transformer from most electronic stores from 240vac to something like 5 or 12v. Then if needed you could look for a AC/DC converter or make one yourself. *i'm sure there'll be some on instructables*. From the 12v you could either wire it in series parallel or just go straight resistors.
ewalk
ewalk
12 years ago
If you are like me, you probably have a bunch of old power adapters laying around, from old cell phones, routers, laptops... Just cut the tip of the connector off and you have a 5v DC(or whatever the adapter is for) ready to plug your LED's into. To be safe and for ease of use, I connect a 4 pin computer power plug to the adapter, then build my circuit with the opposite of the one on the adapter. That way it is safer(not hard wired to the adapter) and it is interchangeable. It is really simple to do. Let me know if you want an instructable for it.
Building Books
Building Books
Answer 12 years ago
An instructable would be a benifit to both me and the community
ewalk
ewalk
Answer 12 years ago
Awesome!! THis will be my first. I will post here with a link when I am done
lemonie
lemonie
12 years ago
Why not just use a low-energy (mains) bulb? L
frollard
frollard
Answer 12 years ago
because this is instructables, and its WAY more fun - and the same cost or less - than to use prefab ones.
Building Books
Building Books
Answer 12 years ago
The speaker of truth speaks wisely!
Building Books
Building Books
Answer 12 years ago
This is pretty much the answer I was looking for. I didn't know what to search for.
keydogstony
keydogstony
12 years ago
Any 9v or 12 V dc ac adaptor will work.
