239Views4Replies
Is there a way i can can control the arduino from a distance
(code and program wise) And not using the arduino's seral monitor? programs could be VB Pytham Pixilate... code ????????????
10 years ago
Use an XBee transmitter and receiver.
Here's a great article that provides all the details along with sample code:
http://www.faludi.com/itp_coursework/meshnetworking/XBee/XBee_program_Arduino_wireless.html
11 years ago
There is a bluetooth arduino. It has a bluetooth-serial adapter built in, so you pair it to the computer, then the virtual serial link is ued by the arduino ide. Theres the xbee radio - you need 2, one on the computer side, one on the arduino as a shield. Works for comms and programming. With both you need an external power source though.
Answer 11 years ago
well the arduino will be 30ft under water so it has to be linked with a usb wire I will end up connecting my arduino to the computor with the xbee for all my other projects. I am stil looking to connect the arduino with VB I am trying to work with the Tilt Sensing Bracelet She uses Processing software
Answer 11 years ago
But the same applies - if you get VB code to open the serial port, you can send and receive data just as you would thru processing - just processing has it built in conveniently.
