386Views3Replies
LED matrix circuit?
So I am trying to make something like this: https://sites.google.com/site/gradcapmod/
to basically make an LED display on a cap. The thing is, I don't want to program anything, just light up a design, wired with a switch to turn on and off. Most instructions are how to program a display using a microcontroller and transisters, etc.
My plan is to use 3mm leds and just solder them together and power it with a 9V. Would that be feasible, wiring the LEDs in parallel strands.
Also, I know that I might want to use resisters to make sure the current isn't too high and burn out the bulbs but I'm not sure where to put them in the circuit or how to calculate it. (I can't make a circuit from looking at a schematic either)
7 years ago
this is a cicuit of a small led cube or so think so i thout it might help with your project good lug
7 years ago
7 years ago
Then you don't need a matrix. Use an LED calc to find out the best wiring and resistors needed for your LEDs using your 9V source. Then Insert your LEDs in the pattern you want and your done. Just be sure to use wires between the LEDs so you have plenty of flexibility in placing your LEDs.
