1751Views3Replies
Author Options:
Manual satellite dish positioner. Answered
I'd like to switch the position of my sky satellite dish between two satellites positions from the ground.?
caitlinsdad
caitlinsdad
11 years ago
You can buy a dish antenna rotator that is motorized for left-right/up-down. Depending on your satellite box, it can issue commands through the coax or else have a separate controller box to move the dish once it is oriented to a starting point. You mount the rotator to the main mast and then the dish to the rotator. Just do a search for it. Good luck.
waldy
waldy
Answer 11 years ago
Hi, thanks believe it's called diseqc. I change satellite very rarely though & don't want to invest in a motor. Looking for some kind of mechanical solution. Perhaps turning a vetical pole, translating to linear movement of dish (with two end stops. best regards Waldy
Sandisk1duo
Sandisk1duo
11 years ago
don't mess around with the dish, you'll screw it up
